| New Reply |
Altitude change in straight flight |
Share Thread |
| Nov21-12, 02:02 AM | #1 |
Hi,
Assume an aircraft starts flying to east with zero pitch and roll, would this aircraft slowly move away from earth surface due to earth being a sphere ? Or would changing gravity direction or some other factor cause this aircraft to fly an arc like path which is parallel to underlying earth surface? Thanks! Paul |
| Nov21-12, 07:05 AM | #2 |
Mentor
Welcome to PF!
The curvature of the earth is so gradual it has no impact here. Straight and level is straight and level. But I suppose if it mattered, the changing direction of gravity would help, since that is the reference point for "level". |
| Nov21-12, 08:49 AM | #3 |
Recognitions:
But air traffic control "flight levels" are defined in terms of local air presssure, not distance above the ground level. For example "Flight level 100" corresponds to 10,000 ft above sea level for the International Standard Atmosphere, but at any moment in time it can vary from about 9,000 to 11,000 feet over different parts of the earth's surface, depending on whether it is summer or winter, or day or night, at a particular place. The basic reason for defining it that way was historical, since all "mechanical" flight instruments work with reference to air pressure. It stiill makes sense even when location systems like GPS are available, because the aircraft's performance (fuel consumption, etc) depends on the air it is flying through, not its distance above the ground. So "level flight" actually means "keeping the air pressure outside the plane constant", not "flying along a mathematical straight line". |
| Nov21-12, 09:16 AM | #4 |
| Nov21-12, 05:17 PM | #5 |
The wings can be at angle of attack relative to the airflow but the aircraft is not pitched.
| Nov22-12, 09:04 AM | #6 |
Mentor
| Nov22-12, 09:05 AM | #7 |
Mentor
| New Reply |
Similar discussions for: Altitude change in straight flight
| Thread | Forum | Replies | ||
| Temperature change with altitude | Classical Physics | 2 | ||
| altitude, gravity, and air density effects on flight | General Physics | 11 | ||
| Which of the following gives the change in altitude of the balloon? | Calculus & Beyond Homework | 5 | ||
| ECEF acceleration in straight and level flight | General Astronomy | 0 | ||
| Change in altitude | Introductory Physics Homework | 1 | ||
