New Reply
Finding eigenvectors of a matrix that has 2 equal eigenvalues
Share Thread Thread Tools
Nov21-12, 07:01 AM   #1
Matrix A=
2 1 2
1 2 -2
2 -2 -1
It's known that it has eigenvalues d1=-3, d2=d3=3
Because it has 3 eigenvalues, it should have 3 linearly independent eigenvectors, right?
I tried to solve it on paper and got only 1 linearly independent vector from d1=-3 and 1 from d2=d3=3.
The method I used was:
[A-dI]v=0
and from this equation I used Gaussian elimination to find v1, v2 and v3
Even wolfram alpha finds only 1 solution from this:
http://www.wolframalpha.com/input/?i...+2y+-+4z+%3D+0
this is the system of equations from [A-3I]v=0 (3 is the eigenvalue d2=d3)
I don't see any way to get 2 linearly independent vectors from this solution
y=0, z=x/2
all i get is vectors
t*[2 0 1]T, t is a member of ℝ
here's matrix A in wolfram alpha: http://www.wolframalpha.com/input/?i...-2%2C+-1%7D%7D
It shows that there is an eigenvector v3 = [1 1 0]T, but i don't see how to get it. Obviously my way to solve this problem doesn't work, so what did I forget to do in my solution or what did I do wrong and why doesn't it work this way?
PS. I'm not sure if this should be in the homework section, because this is more like a general problem and I don't understand why doesn't it work the way i tried to solve it. Matrix A could be any matrix with two equal eigenvalues.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov21-12, 01:25 PM   #2
Recognitions:
Homework Helper Homework Help
when a matrix has r equal eigenvalues, the number of eigenvectors (using complex numbers) can be anywhere from one to r.
e.g. a square 2by2 matrix which has a "1" in the upper right hand corner, and all other entries zero, has only one eigenvector.
a square r by r matrix which has s ones just above the diagonal and all other entries zero, should have r-s eigenvectors.
Nov21-12, 01:34 PM   #3
Quote by mathwonk View Post
Ok, but according to wolfram alpha this matrix still has 3 eigenvectors, and I'm wondering why can i only find the first two eigenvectors using the method i used?
Nov21-12, 06:51 PM   #4
When I solve (A-3I)X=0, I find two linearly independent solutions, i.e. eigenvectors to the eigenvalue 3:
[1 1 0]T and [2 0 1]T.
Nov21-12, 07:20 PM   #5
Quote by Erland View Post
Thanks,
I tried it again and now I get it. I just made a little mistake calculating 2-3 (not -5)
It's weird because I counted this twice (did the same mistake twice) and checked that I had counted everything totally right but didn't notice this.
Nov22-12, 10:37 AM   #6
Recognitions:
my point was that your question:
"Because it has 3 eigenvalues {-3,3,3}, it should have 3 linearly independent eigenvectors, right?"
has answer
"no, not right."
and misunderstanding this general principle is more harmful in the long run than adding 2 and -3 and getting -5.
Nov22-12, 02:16 PM   #7
has answer
"no, not right."
yes, i understood that as well, thanks
New Reply
Thread Tools
Similar Threads for: Finding eigenvectors of a matrix that has 2 equal eigenvalues
Thread Forum Replies
Repeating eigenvalues and diagonalizing Calculus & Beyond Homework 6
Diagonalizing a symmetric matrix with non-distinct eigenvalues Calculus & Beyond Homework 4
Diagonalizing a square matrix with degenerate eigenvalues Quantum Physics 4
Eigenvalues for a matrix with equal and opposite diagonal entries? Linear & Abstract Algebra 3
