| New Reply |
Volume of 1 mole of Gas at STP |
Share Thread | Thread Tools |
| Sep24-11, 08:27 PM | #1 |
Can anyone give an explanation (other than algebraically) as to why one mole of a gas under Standard Temperature and Pressure and behaves like an ideal gas will always have the same volume (22.4 L)?
| Sep24-11, 09:40 PM | #2 |
Recognitions:
pV=nRT for an ideal gas, so if temperature and pressure are constant, then so is volume.
The reason the volume is the same for any ideal gas is because an ideal gas uses the assumption that the molecules are much smaller than the volume of the gas, and they collide elastically and there are no intermolecular forces, so for these reasons, the type of molecule won't affect the equation above. |
| Sep25-11, 04:24 PM | #3 |
Moreover, for an Ideal Gas, you don't even have to stick with NTP. No matter what the temperature and no matter what the pressure, the number of molecules in a fixed volume will be exactly the same for any gas or any mixture of non-reacting gases. |
| Sep26-11, 08:00 AM | #4 |
Recognitions:
Volume of 1 mole of Gas at STPIn the case of a gas: n/V = P/RT AM |
| Sep26-11, 02:59 PM | #5 |
I can see how my wording might be interpreted in a way that I did not intend. What I meant was that for any specific temperature (T) and for any specific pressure (P), the number of molecules per cubic meter (n) is the same for any gas or any mixture of non-reacting gases. n = P/kT
| Sep26-11, 06:47 PM | #6 |
Recognitions:
AM |
| Nov29-12, 08:19 AM | #7 |
I understand that the number of molecules in an isolated system will remain the same, no matter what you expand the volume to, raise the temperature to etc.
But how can the equation N=P/kT (I'm going to assume you meant uppercase N for number of molecules there, rather than lowercase n for moles) be derived from PV=NkT; completely disregarding V? |
| Nov29-12, 09:09 AM | #8 |
So when he writes n=P/kT you should read it as n/V = P/kt. Obviously that's algebraicly equivalent to PV=NkT. |
| New Reply |
| Thread Tools | |
Similar Threads for: Volume of 1 mole of Gas at STP
| Thread | Forum | Replies | ||
| Calculating 100ml with a mole vs mole ratio | Biology, Chemistry & Other Homework | 0 | ||
| Mole homework help | Biology, Chemistry & Other Homework | 6 | ||
| Mole equation | Biology, Chemistry & Other Homework | 1 | ||
| AMU & Mole | Biology, Chemistry & Other Homework | 9 | ||
| Why is C not 12g/mole? | Chemistry | 7 | ||
