New Reply
How to solve for solutions to the diophantine 5b^2*c^2 = 4a^2(b^2+c^2)
Share Thread Thread Tools
Dec3-12, 09:39 AM   #1
I am trying to find a way to generate solutions to 5b^2*c^2 = 4a^2(b^2+c^2)
Can anyone offer some insight?
I know that (b^2+c^2) is the part that is divisible by 5
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec3-12, 10:55 PM   #2
Recognitions:
Homework Helper Homework Help
The interesting cases will be when HCF(a,b,c)=1, so assume that. First, consider what cases that leaves where some two of the three have a common factor.
When no two have a common factor, look for an interesting factorisation. With squares, that's typically going to be of the form (x-y)(x+y). Hint: try writing the 5 as 4+1.
Dec3-12, 11:09 PM   #3
Quote by haruspex View Post
I am sorry, I don't really understand what you mean here at all. Can you provide an example?
Dec4-12, 12:39 AM   #4
Recognitions:
I'm suggesting breaking the problem into 3 cases:
1. a, b, c have a common factor. This is trivially reducible to the other cases by factoring it out.
2. Some pair of a, b, c have a common factor. E.g. consider p divides a m times and b n times. Then you can show either p = 2 or m=n, and maybe deduce some more consequences.
3. No two have a common factor.
Rewrite the equation as 4b2(c2-a2) = c2(4a2-b2) then factorise. What can the prime factors of c divide on the LHS?
Dec4-12, 12:47 AM   #5
I know you are trying to help but I sincerely have absolutely no idea what that aims to solve?
It seems like you're advocating some form of just iterating through all a,b,c in order to get all the cases and break them out into these three categories, but I'm not sure how this is any better than brute force.
1. You're saying gcd(a,b,c)>1 here?
2. either gcd(a,b)>1, gcd(a,c)>1, or gcd(b,c)>1?
3. gcd(a,b,c)=1
How does rewriting the equation that way help, and factorize which part?
If it helps any, I am only looking for cases for which gcd(a,b,c)=1 and a<b<c<2*a
Dec4-12, 12:55 AM   #6
for example
[209, 247, 286],
[341, 374, 527],
[779, 950, 1025],
[1711, 2146, 2183]
... etc
Dec4-12, 01:13 AM   #7
Lastly, I just tried looking at the prime factors of c with respect to the lhs and nothing unusual cropped up (for instance using the cases I just posted). It's not like the primes all exclusively divide 4b^2 or (c^2-a^2) if that's what you're saying.
It can divide 4*b*b*a*a though; not sure if this matters
Dec4-12, 03:10 AM   #8
Recognitions:
No, not brute force. I'm suggesting that in each case you can make interesting but different logical deductions which might eventually allow you to characterise all solutions.
Take e.g. gcd(a,c)=1 and gcd(b,c) = 1. Then c = 1 or 2. Indeed, if gcd(a,b)=1 then b|c.
Dec4-12, 04:35 AM   #9
Quote by SeventhSigma View Post
Why?
Dec4-12, 07:22 AM   #10
I don't know why Dickfore; it just is
haruspex: Yes but I am after the gcd(a,b,c) = 1 cases which don't seem to have those same unique attributes
Dec4-12, 08:27 AM   #11
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
That doesn't really make any sense. If you don't know why, then why did you add the condition?? Is it given in the problem statement that 5 divides [itex]a^2+b^2[/itex]?? Or...
Dec4-12, 02:34 PM   #12
Recognitions:
Well, that is very easy to prove.
Yes, I understand that. The cases I elaborated upon, like (a,b)=1, necessarily satisfy (a,b,c)=1. Do you mean you are most interested in the cases where (a,b,c)=1 but some pair does have a common factor? Or perhaps where each pair has a common factor?
Dec4-12, 05:40 PM   #13
Recognitions:
Doesn't (b^2 + c^2) or a^2 have to be divisible by 5 as the left side of the equation has 5 as a factor. Also b or c must be even as 5(B^2)(C^2) is equal to 4 times a number.
Dec4-12, 08:54 PM   #14
Apparently, it isn't for the OP. If one is incapable of verifying this statement, then the analysis you suggested is beyond their comprehension.
Dec4-12, 08:57 PM   #15
Quote by coolul007 View Post
Doesn't (b^2 + c^2) or a^2 have to be divisible by 5?
So, what if we assume that [itex]b^2 + c^2[/itex] is not divisible by 5?
Dec4-12, 09:07 PM   #16
I've since figured out my own problem, no need to discuss this any further
Dec5-12, 01:48 AM   #17
Hi SeventhSigma,
I am always fascinated by solutions to Diophantine equations.
I am glad that you figured it out, but we haven't learned anything
from this discussion. Can you please share your solution with us?
Thanks,
LittleNewton
New Reply
Thread Tools
Similar Threads for: How to solve for solutions to the diophantine 5b^2*c^2 = 4a^2(b^2+c^2)
Thread Forum Replies
What is a systematic method to solve this Diophantine equation? Calculus & Beyond Homework 6
solutions of a diophantine equation Linear & Abstract Algebra 1
Diophantine and coprime solutions x,y Linear & Abstract Algebra 2
Accelerated C++ book - no solutions for exercises, should I still solve them? Engineering, Comp Sci, & Technology Homework 22
Newton (iterative) method to solve a diophantine equation Linear & Abstract Algebra 5
