New Reply
Charts of a torus (and other manifolds)
Share Thread Thread Tools
Dec3-12, 08:25 PM   #1
Ok, so this relates to my homework, but I really can't find an answer anywhere, so this is more of a general question. First off, what does a "chart" of a manifold look like? Is it a set, a function, a drawing, a table, what?! I have found so many things about charts, but nothing shows what they actually look like (either that or I am just not recognizing them). Secondly, using stereographical projection, what are the 4 charts of a torus? I saw something that looked something like
x1 = ((cosΘ, sinΘ), (cosφ, sinφ))= Θ
x2 = ((cosΘ, sinΘ), (cosφ, sinφ))= φ
and the other charts are similar. Would the other charts just be
y1 = ((cosΘ, sinΘ), (cosφ, sinφ))= Θ
y2 = ((cosΘ, sinΘ), (cosφ, sinφ))= φ
I'm just really confused on this topic and I would like to gain a little more confidence before going into my final. Are the "charts" that I gave actually charts, and are they the ones that describe a torus?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec4-12, 08:44 AM   #2
Recognitions:
On the sphere of radius 1 in 3 space centered at the origin you have four charts. Project the upper hemisphere onto the xy-plane by dropping the z coordinate. Project the lower hemisphere the same way. then rotate the sphere 90 degrees and do it again.
Dec4-12, 02:06 PM   #3
A chart is a map that you use to navigate your way through some area. For example, the USGS makes a ton of maps so that you can look at the appropriate chart to check out the local terrain/landmarks. Usually, charts are marked to show latitude and longitude. These are coordinates that tell you where you are on that chart.
An atlas is a book of charts that covers all the places of interest.
The meaning of chart/atlas in manifold theory is the same in spirit. A chart is a map of the area near a point and the points on the charts have rectangular coordinates that tell you where you are on the chart. Given a manifold there are an infiinte number of charts. Just like on the globe there are an infinite number of possible charts because a chart is determined by the exact area I want to map and also by the manner in which I want to assign coordinates to the points on the chart (You dont' have to use latitude/longitude, you could make up another way to assign coordinates).
Formally speaking, a chart consists of an open set U in the manifold, and a bijective mapping
[itex] \varphi: U\rightarrow \mathbb{R}^n .[/itex]
The image of the mapping is your flat "map" of the region U.
The mapping you described does give a chart of the torus though to be precise you need to specify the domain and range so that you have a 1-1 mapping. The fact that you need more than 1 chart is a reflection of the fact that a single flat map cannot smoothly cover the torus unless you wrap it on itself.
Dec4-12, 10:00 PM   #4
Recognitions:
If you think of the torus as a rectangle in the plane with opposite edges identified then you can get a coordinate system as
1) the interior of the rectangle
2) an open square around the corner,
3) an open rectangular strip along two perpendicular edges excluding the end points
Each of these is a diffeomorphism of an open neighborhood on the torus into an open neighborhood in the plane
New Reply
Thread Tools
Similar Threads for: Charts of a torus (and other manifolds)
Thread Forum Replies
Charts of a Torus Calculus & Beyond Homework 0
Submanifolds vs Manifolds / Immersion vs Charts Differential Geometry 4
Show orthogonal matrices are manifolds (Munkres Analysis on Manifolds) Calculus & Beyond Homework 10
How Do I Get Old Synoptic Charts? Earth 2
Concerning charts on a manifold Differential Geometry 6
