Thermodynamics- Heat engine and refrigeration
The discussion focuses on the thermodynamic efficiency of a nuclear power plant generating 2000 MW of heat energy, with an actual electric power output of 700 MW. The maximum thermal efficiency calculated is 47.1%, while the actual efficiency is 35%. The challenge lies in determining the exit temperature of cooling water from the condenser, which was initially miscalculated due to a misunderstanding of unit conversions. After correcting the calculations, the final exit temperature of the cooling water is determined to be 27.3°C.
  • Understanding of thermodynamic efficiency and its calculations
  • Familiarity with the principles of heat engines and refrigeration cycles
  • Knowledge of unit conversions, particularly between megawatts and watts
  • Proficiency in using the equation Q=McΔT for heat transfer calculations
  • Study the Carnot efficiency and its implications for thermal systems
  • Learn about the design and operation of nuclear power plants
  • Explore advanced heat exchanger designs and their efficiencies
  • Investigate the impact of cooling water temperature on thermal efficiency
Students and professionals in thermodynamics, nuclear engineering, and energy systems, as well as anyone involved in optimizing power plant efficiencies.
MacLaddy
A nuclear power plant generates 2000 MW of heat energy from nuclear reactions in the reactor's core. This energy is used to boil water and produce high-pressure steam at 300° C. The steam spins a turbine, which produces 700 MW of electric power, then the steam is condensed and the water is cooled to 30° C before starting the cycle again.
A: What is the maximum possible thermal efficiency of the power plant?
B: What is the plant's actual efficiency?
C: Cooling water from a river flows through the condenser (the low-temperature heat exchanger) at the rate of [itex]1.2 \times 10^{8}\;{\rm L}/{\rm hr}[/itex] ( approx 30 million gallons per hour). If the river water enters the condenser at [itex]18^\circ \rm C[/itex], what is its exit temperature in C°?
Q=McΔT
I have solved the first two problems.
A = 47.1%
B = 35%
It is C that I am having difficulties with.
If 2,000 MW are going into the system, and only 700 MW are used, then 1,300 MW should be fed into the cold reservoir.
Solving for Joules per second.
[itex]1,300MW=1.3*10^6 \frac{J}{s}[/itex]
Solving for volume per second.
[itex]1.28*10^8\frac{L}{hr}*\frac{1hr}{3,600s}*\frac{1m^3}{1,000L}=\frac{100}{3}\frac{m^3}{s}[/itex]
Solving for mass.
[itex](M)kg=(1,000\frac{kg}{m^3})(\frac{100}{3}\frac{m^3}{s})=\frac{100,000}{3}kg/s[/itex]
[itex]Q=Mc\Delta T[/itex]
[itex]1.3*10^6 J = (\frac{100,000}{3}kg)(4190\frac{J}{kg*K})(T_f K-291 K)[/itex]
Solving for this, I get
[tex]\frac{1.3*10^6 J}{(\frac{100,000}{3}kg)(4190 \frac{J}{kg*K})}+291 K = T_f = 291.0093 K = 18.009^{\circ} C[/tex]
As this is not the correct answer, I am definitely doing something wrong.
Any help would be appreciated.
Mac
How many watts is 1300 MW? It's 1300 * 10^6 W
Oh, well that was dumb of me. I was just taking it for granted that 1 MW was 1000 Watts without even looking it up.
I plugged it the correct numbers and that worked. It gave me a final answer of 27.3 K.
Thank you very much for your help.
Mac
