Register to reply
Can I get a 40KN force from a hydraulic cylinder powered by an electric motor?
by SteveAlex
Tags: 40kn, cylinder, electric, force, hydraulic, motor, powered
Share this thread:
SteveAlex
#1
Dec5-12, 05:58 AM
P: 4
Im thinking of designing a tipping trailer for a car. I need a force of 40KN exerted to tip but would this be too much for driving with an electric motor powered by the car battery. If not what size of motor and pump would I need? thanks
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
K^2
#2
Dec5-12, 06:24 AM
Sci Advisor
P: 2,470
With hydraulics, you can get absolutely any force with absolutely any power input. You can hand-crank 40kN with hydraulics. In fact, I'm pretty sure you could find a hydraulic car lift that does just that.
Now, if you have a force, say these 40kN, and the time in which you want to raise the load a certain distance, you can get power. Say you want to raise 40kN load 1 foot in 1 minute. That works out to roughly 200W. Factor in loses, both mechanical and electrical, and you are probably looking for a 300-400W motor. At 12V, that works out to something in the 25-35 amp range. You should be able to draw that from a car battery.
SteveAlex
#3
Dec5-12, 07:46 AM
P: 4
Thank you for reply, very helpful
CWatters
#4
Dec7-12, 03:54 AM
P: 3,100
Just for completeness the equation K^2 is using is ..
Power = Force * velocity = force * distance/time
Force in Newtons
Distance in Meters
time in seconds
Power in watts
If drawing 25A think about the wire guage needed and use appropriatly rated switch and fuse. A standard 30A rated switch might not last very long as the startup current could be much higher than 25A.
Perhaps assume the motor is only 60-80% efficient? The pump?
Register to reply
Related Discussions
Calculating force of hydraulic cylinder Classical Physics 2
Hydraulic powered stone saw Engineering Systems & Design 0
Electric vs. Hydraulic Motor General Engineering 6
Linear force transfered from an electric motor to a screw. Mechanical Engineering 12
Electromagnetic force in electric motor Classical Physics 7
