New Reply
dU/dt = 0 for oscillating spring, help with derivation
Share Thread Thread Tools
Dec6-12, 06:50 PM   #1
U = energy
In the book:
[itex] \frac{dU}{dt} = \frac{d}{dt} (\frac{1}{2} mv^2 + \frac{1}{2} kx^2) [/itex]
then we have [itex] m \frac{d^{2}x}{dt^2} + kx = 0 [/itex] because [itex] v = \frac{dx}{dt} [/itex]
however they get rid of [itex] \frac{dx}{dt} [/itex] .
They are ignoring the case where v = 0, because then [itex] m \frac{d^{2}x}{dt^2} + kx [/itex] doesn't have to be zero, and it can still satisfy the equation.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec6-12, 07:00 PM   #2
Recognitions:
Homework Helper Homework Help
If you have y = (dx/dt)^2 and you put u = dx/dt
then y=u^2 such that dy/du = 2u and du/dt = d^2x/dt^2
So dy/dt = 2u*du/dt = 2(dx/dt)(d^2x/dt^2)
In your original equation, differentiating the KE term and the spring term will give you a dx/dt which can be canceled out since dU/dt= 0.
Dec6-12, 07:01 PM   #3
You should edit the post and replace [; ... ;] with [i tex] ... [/i tex]
(get rid of the space in [i tex]. I put that in so the parser wouldn't detect it.)
Dec6-12, 07:08 PM   #4
yes, i get it but if dx/dt = 0, which it can, then the equation is satisfied and the other term doesn't have to be zero. However, we are saying the other term must always be zero.
Dec7-12, 07:50 AM   #5
mfb
Mentor
dx/dt = 0 is true for a two point in time per period only, or for a non-moving spring in equilibrium. That is not relevant for the general case.
New Reply
Tags
springs mechanics
Thread Tools
Similar Threads for: dU/dt = 0 for oscillating spring, help with derivation
Thread Forum Replies
oscillating spring derivation Introductory Physics Homework 2
Help with oscillating spring and energy Introductory Physics Homework 1
amplitude of oscillating spring Advanced Physics Homework 3
Solving for Spring Constant of Oscillating Spring Introductory Physics Homework 2
Oscillating Gate with spring. Engineering, Comp Sci, & Technology Homework 1
