Help With Conservation Of Energy Concept
The discussion revolves around the conservation of energy in the context of an asteroid approaching Earth, specifically examining the interplay between gravitational potential energy and kinetic energy. Participants explore the implications of energy transformations as the asteroid moves closer to Earth, considering both theoretical and practical aspects of the scenario.
  • Bob questions how energy is conserved as both kinetic energy and gravitational potential energy appear to increase as the asteroid approaches Earth.
  • Some participants point out that Bob's equation for gravitational potential energy is missing a crucial minus sign, indicating that gravitational potential energy decreases (becomes more negative) as the asteroid approaches Earth.
  • Dave suggests that the size and mass of the asteroid may affect the significance of gravitational potential energy compared to kinetic energy, noting the high velocities of incoming asteroids.
  • Another participant emphasizes that gravitational acceleration decreases with distance from Earth, which affects the speed of the asteroid as it falls, leading to significant kinetic energy upon impact.
Participants express differing views on the correct formulation of gravitational potential energy and its implications for energy conservation. There is no consensus on the initial misunderstanding of energy transformations, and the discussion remains unresolved regarding the specific contributions of kinetic and potential energy.
Limitations include the omission of specific asteroid sizes and masses in calculations, which could influence the discussion on energy contributions. Additionally, the assumptions regarding the initial conditions and the effects of gravitational acceleration at varying distances from Earth are not fully explored.
bobbles22
Hi guys,
Can someone help explain something to me.
In a situation of an asteroid heading straight towards the Earth, I'm trying to understand where the energy comes and goes (using just gravitational potential energy and kinetic energy). Consider the energy of the asteriod some distance away from the surface of the Earth, then just before impact.
I'm using the following equations:
Kinetic Energy = Ek = 0.5mv2
Gravitational Potential Energy = Eg = (GMm)/r
My question is that, ignoring friction/sound etc, initially the asteroid has a certain speed and thus a certain kinetic energy, simple to work out. It also has a gravitational potential energy based on G and the masses involved and the separation. However, as it gets closer, the force from the Earth increased, as the separation 'r' off the objects decreases, the gravitational potential energy increases. At the same time, as the force on the asteroid increases, we expect the speed to increase so in effect, both Ek and Eg are both increasing. If both are increasing, then where is the energy coming from.
Surely it should be Eearly = Ek + Eg = Elater = Ek + Eg
Can anyone give me a basic idea of where I'm going wrong with this idea please.
Many thanks
Bob
Where you are going wrong is with your equation for Gravitational Potential Energy:
You left out the all-important minus sign in front:
GPE = -(GMm)/r
Using the correct expression, you'll see that the GPE decreases (becomes more negative) as objects approach and r decreases.
See: Gravitational Potential Energy
You omitted a minus sign. In this situation, we consider Eg to be negative.
No, the gravitational potential energy decreases as the object approaches the Earth, the same as an object close to the Earth for which we usually use Eg = +mgh. Including a minus sign in your equation for Eg takes care of this.
just a though to put out there ( I am not a maths guy )
you haven't given an example of the size/mass of an asteroid for your calcs
I would consider that the difference in size of say an asteroid up to ~ 1km across compared to the size of the earth, the gravitational PE may not be a large factor compared to the KE of the incoming asteroid.
average incoming velocity of a meteor/asteroid ... 30 - 40 km / sec
acceleration due to gravity 9.81m/s2 ... big difference, orders of magnitude
some one more knowledgeable than me will hopefully clarify more
Dave
Thanks Doc and JT
that gave me some insight too :)
Dave
But look at the units... The acceleration is measured in meters per second per second, meaning that every second the speed increases by 9.8 meters/sec... Let that go for a few hundred seconds and you've built up some serious speed. (note: gravitational acceleration is only 9.8 m/sec at the surface of the earth; it declines steadily the further away from Earth you are).
It turns out that an object falling from infinity to the surface of the Earth will reach a speed of about 11 km/sec; that's its gravitational potential energy being converted into kinetic energy. It's a lot.
  • · Replies 21 ·
  • · Replies 41 ·
  • · Replies 77 ·
