Register to reply
Induced electric field
Share this thread:
dev70
#1
Dec11-12, 01:13 PM
P: 58
Can electric field be induced at a point near a time varying uniform magnetic field? "Near" means not the in the place where magnetic field exist. But at a point outside the field's presence.
Phys.Org News Partner Physics news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
What is Nothing?
How computing is transforming materials science research
mfb
#2
Dec11-12, 05:03 PM
Mentor
P: 11,840
You can induce electric fields everywhere. Why do you expect that it would not be possible somewhere?
Meir Achuz
#3
Dec12-12, 12:12 PM
Sci Advisor
HW Helper
PF Gold
P: 2,010
Quote Quote by dev70 View Post
You probably meant 'by a magnetic field, but not in the place where the magnetic field exists.
A time varying magnetic field will have time varying vector potential
[tex]\frac{\partial{\bf A}}{\partial t}[/tex] that can exist beyond the field, and induce an E field. This is like the 'Aharonov-Bohm' effect.
elfmotat
#4
Dec12-12, 12:42 PM
elfmotat's Avatar
P: 260
Yes. Say, for example, there's a long solenoid with a time-varying current I(t) running through it. The resulting magnetic field is nonzero only inside the solenoid. However, (assuming ∂B/∂t isn't zero) the electric field induced will also be nonzero outside of the solenoid.
mfb
#5
Dec12-12, 02:04 PM
Mentor
P: 11,840
Quote Quote by Meir Achuz View Post
Only in areas where there is a changing magnetic field.
Quote Quote by elfmotat View Post
∂B/∂t ≠ 0 implies that there is a magnetic field (apart from some specific points in time maybe).
andrien
#6
Dec13-12, 01:08 AM
P: 1,020
Take a circular area beyond the region of changing magnetic field,but it should include changing magnetic field area then
E.2∏R=-∏r2.∂B/∂t,E is induced in region beyond WHERE B changes.
Meir Achuz
#7
Dec13-12, 03:53 PM
Sci Advisor
HW Helper
PF Gold
P: 2,010
Quote Quote by mfb View Post
B= curl A. Apply Stokes' theorem for a B field in a solenoid.
This gives an A outside the solenoid, where there is no B.
mfb
#8
Dec13-12, 03:59 PM
Mentor
P: 11,840
I don't see how your quote and your post are related. You can get a non-zero A everywhere if you like - even in a perfect vacuum, as you have gauge freedom. But you do not get an electric field without a changing magnetic field or some charge distribution.
elfmotat
#9
Dec13-12, 04:24 PM
elfmotat's Avatar
P: 260
Yes, but only inside the solenoid. The electric field it produces also "exists" (is nonzero) outside the solenoid where B=0.
mfb
#10
Dec13-12, 04:47 PM
Mentor
P: 11,840
Sorry, but what you want just violates the laws of physics.
$$curl(B)=\frac{1}{c}\frac{\partial E}{\partial t} + \frac{4\pi}{c} j$$
You do not want currents and no magnetic field? => electric field is time-invariant. You cannot switch it on or off.
This means that a time-independent charge distribution (which might consist of moving charges) is the only relevant option for a source of an electric field.
elfmotat
#11
Dec13-12, 05:56 PM
elfmotat's Avatar
P: 260
No, it certainly doesn't. If there's a long solenoid of radius a and turn density n with a current I(t) running through it, it will induce a magnetic field B(t)=μ0nI(t) inside the solenoid. Outside of the solenoid B=0 everywhere.
Evaluating the integral ∫E∙ds=-∂/∂t ∫B∙dA ⇔ E=-μ0na2 I'(t) / 2r
Even though B=0 outside the solenoid, it still produces a nonzero E outside the solenoid.
K^2
#12
Dec13-12, 06:30 PM
Sci Advisor
P: 2,470
Transformers violate laws of physics? You learn something new every day!
Sorry, I shouldn't be mean about it. It is a bit counter-intuitive. But yeah, if you take an infinitely-long solenoid, the magnetic field is ONLY present inside the solenoid. Yet you can wrap another solenoid around it, and induce a current on it by time-varying the current on the inner-solenoid. The B-field outside remains zero, but E-field is non-zero.
This all has to do with curl of the electric field being governed by ∂B/∂t. Outside of the solenoid, both curl and divergence of E is zero, but it doesn't mean that the field itself is zero. Feel free to verify that circular E field with 1/R intensity satisfies conditions of both curl and divergence being zero. (In other words for [itex]E = E_0\frac{\hat{\phi}}{r}[/itex], [itex]\nabla \cdot E = 0[/itex] and [itex]\nabla \times E = 0[/itex] everywhere except r=0.)
andrien
#13
Dec14-12, 02:06 AM
P: 1,020
I have shown in post no.6 that even outside a solenoid if one take a circular area and if it encloses the region of changing magnetic field then electric field will be induced at far distances also.
mfb
#14
Dec14-12, 07:50 AM
Mentor
P: 11,840
Ah ok, you are right. So we need a coil of infinite length, where B(t) changes linear in time. This gives a constant (in time), circular E(t) and no magnetic field outside.
dev70
#15
Dec20-12, 09:35 AM
P: 58
then..how will a time varying electric field induce magnetic field and where?
Register to reply
Related Discussions
Induced Magnetic Field in a Non-Uniform Electric Field Introductory Physics Homework 9
Induced Electric Field Introductory Physics Homework 8
Changing Magnetic Field Causes Induced Electric Field Introductory Physics Homework 1
Induced Electric Field Classical Physics 42
Induced Electric Field General Physics 6
