New Reply
Moving an object over predetermined trajectory
Share Thread Thread Tools
Dec13-12, 03:53 AM   #1
Need some guidance on how to approach the following scenario
Object : 200 grams
movement axis : x, y, z
distance : 20 meters
speed : 70 to 150 kmph adjustable.
The plan is to have 3 motors on a jig to control the movement on 3 axis.
The issue is to reach 50 m/s speeds and braking.
alternatively is to look at magnetic tunnel but the power requirement
adn control seems expansive.
Any suggestion on a motor that is available that can reach 50 m/s
over 20 meters? the Y axis and z axis motors will be driven by the
x axis motor hence the object weight will be more when it
comes to the x axis motors which moves the jig across 20mts
at 50 m/s
appreciate any guidance on the same
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec14-12, 04:10 PM   #2
Mentor
Quote by andyasky View Post
Object : 200 grams
at 50 m/s
Welcome to the PF.
Maybe use a model rocket motor?
New Reply
Thread Tools
Similar Threads for: Moving an object over predetermined trajectory
Thread Forum Replies
Measuring distances between a moving object and a stationary object using light Special & General Relativity 8
Collision. A moving object hits a stationary object and moves at an angle Introductory Physics Homework 8
retarding force, freely moving object, impact stationary object, rest without rebound Engineering, Comp Sci, & Technology Homework 2
Collision between two moving objects (one with a non-known trajectory)? Classical Physics 1
3D Velocity Of A Moving Object To A Stationary Object General Physics 3
