Question regarding Simple Harmonic Motion
The problem involves two linear simple harmonic motions with equal amplitudes and angular frequencies ω and 2ω, affecting a particle along the X and Y axes, respectively. The initial phase difference between the motions is π/2, and the goal is to determine the resultant path of the particle.
  • Participants discuss various attempts to express the motions parametrically, including using sine and cosine functions. There is a focus on eliminating the ωt term to find a relationship between x and y. Some participants express confusion regarding the phase difference and its implications on the resulting equations.
Multiple attempts have been shared, with some participants noting discrepancies between their results and textbook answers. There is ongoing exploration of the relationships between the equations derived from different assumptions about phase differences. Guidance has been offered regarding the nature of Lissajous curves and the interpretation of phase differences.
Participants are navigating through the implications of phase differences and the correctness of their parametric representations. There is mention of a potential typo in one of the attempts, and the discussion highlights the complexity of deriving consistent results from different approaches.
sankalpmittal
The two linear simple harmonic motions of equal amplitudes , and angular frequencies ω and 2ω are imposed on a particle along the axes of X and Y respectively. If the initial phase difference between them is π/2 , then find the resultant path followed by the particle.
http://en.wikipedia.org/wiki/Simple_harmonic_motion
I tried solving question using x= a sinωt
And other is y=a sin(2ωt + π/2)
Solving them , I get the wrong answer in terms of x and y...
Please help !
Thanks in advance...
:smile:
Can you show how you went about "solving them"? We need to see your attempt if we're to know how to help.
Hi sankalpmittal,
Show please what you have tried?
x=sin(ωt) and y=sin(2ωt+π/2) =cos(2ωt) is the parametric representation of a Lissajous curve. See http://en.wikipedia.org/wiki/Lissajous_curve
Try to eliminate the ωt term.
ehild
ehild said:
Hi sankalpmittal,
ehild
Firstly I solved this question using :
a : Amplitude
x=a cosωt
y=a sin(2ωt+π/2)
y=a cos (2ωt)
y= a( cos2ωt-sin2ωt)
y= a(2cos2ωt-1)
y= a{(2x2/a2)-1)
I noticed that this does not match the answer given in my textbook...
Then I made a second attempt :
x=a sinωt
y=a sin (2ωt+π/2)
y=a cos(2ωt)
y= a(1-2sin2ωt)
y= a{1-(2x2/a2)}
Again this does also not match with the answer in my textbook...
Then I made the third attempt :
x= a cosωt
y= a cos(2ωt+π/2)
y= -asin(2ωt)
y= -2a sin(ωt)cos(ωt)
y=-2a √(1-sin2ωt) (x/a)
y=-2a √{1-(x2/a2)} (x/a)
On squaring both sides and simplifying , I got :
y= 4x2{1-(x2/a2)}
This answer matched with the answer given in my textbook...
I just wanted to know , where I went wrong in my first and second attempt...
a : Amplitude
x=a cosωt
y=a sin(2ωt+π/2)
y=a cos (2ωt)
They are ins phase, instead of being shifted by pi/2.
x=a sinωt
y=a sin (2ωt+π/2)
y=a cos(2ωt)
y= a(1-2sin2ωt)
y= a{1-(2x2/a2)}
That is correct, if x and y are as you assumed.
x= a cosωt
y= a cos(2ωt+π/2)
y= -asin(2ωt)
y= 4x2{1-(x2/a2)}
But this answer is wrong as y is not squared. It was correct before squaring.
If you add two perpendicular vibrations you can have different y(x) curves, depending on the initial phases.
ehild
ehild
OK , so there was a typo. The answer I got in my third attempt was y2=4x2{1-(x2/a2)} , which matched with the answer given in my textbook. But unfortunately the answer which I got in my first and second attempt , did not match with that given in my textbook.
According to you , both the equations , in my second and third attempt are correct , yet they are different and only latter match with the answer in my textbook. How ?
Also what do you mean by "in phase and not shifted by pi/2" in my first attempt ? Can you explain a bit comprehensively ?
Your first attempt was
x=a cosωt
y=a sin(2ωt+π/2) which is equivalent to
y=a cos (2ωt)I do not see any initial phase difference between x and y.
Your second attempt is true and so is the third one. Phase difference between x and y is not a clear concept. You get x,y curves of different form if x=sin(ωt), y=cos(2ωt) (y=1-2x2) and when x=cos(ωt) and y=sin(2ωt) (y2=4x2(1-x2))
ehild
A better link to consider might be: http://en.wikipedia.org/wiki/Lisajous .
Also see: http://en.wikipedia.org/wiki/Lemniscate_of_Gerono .
  • · Replies 51 ·
  • · Replies 17 ·
