New Reply
Balancing forces on a bicycle wheel
Share Thread Thread Tools
Dec16-12, 04:08 AM   #1
Hi, (this is not a homework question)
If I have a bicycle with COM, M (in line with the center of the wheels, C) on an incline, angle Φ, and the bicycle is NOT moving at all because the brake is on at B.
I am trying to put in the forces acting on the wheel. I figure that the weight of the bicycle is probably acting through the center of the wheel because the COM is at the same height (would this change if the COM was in a different place?). And because the wheel is not moving laterally I figure the friction force is opposing the weight, but acting at ground level.
The brake is preventing the wheel from turning CCW, and so I think the ?? force from the brake needs to also be mgsinΦ in a CW direction. But the problem is that if I put the brake/?? force in, the static/overall forces on the wheel won't balance and the wheel should move off in the direction of the ?? force.
Help!?
thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec16-12, 05:14 AM   #2
K^2
Recognitions:
Quote by peanutaxis View Post
First of all, force from the frame is acting on center, right. That's property of the axis, so it will not change even if CoM is higher/lower.
You are also correct that the friction will be equal to weight's projection along the incline. No problem there.
What you are forgetting about is Newton's 3rd Law for the brake. If brake is applying force on wheel, wheel is applying force back on the brake. That force would accelerate the bike backwards if it weren't attached to the wheel. So rather than just bike's weight, front wheel experiences bike's weight plus the reaction force of the brake through it's center.
Now you can balance the tangential forces. Keep in mind that you also have normal forces on the wheel, and that normal force on the two wheels together adds up to component of weight perpendicular to the incline.
Dec16-12, 04:45 PM   #3
Quote by K^2 View Post
But the whole thing is stationary, so Newton's 3rd applies to everything! So that doesn't help me: The wheel is pushing on the ground equally and opposite to the Friction force pushing on the wheel, and the wheel is pulling on the bicycle mass equally and opposite to the bicycle mass pulling on the wheel.
What I am trying to do is find the forces acting on the wheel.
The wheel is not moving laterally, so the friction force must be opposed equally by the bicycle weight.
The wheel is not rotating, so the torque due to the friction and the weight force must be opposed equally by the torque from the brake? How do you work these out?
thanks,
p
Dec16-12, 06:31 PM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
The component of the bike's weight perpendicular to the ground is balanced by force of the earth on the wheels. Since the bike is on slanted ground there is also a component of weight parallel to the ground. That will be balanced by the friction force on the wheels which is transmitted to the brakes that prevent the wheels from turning.
New Reply
Thread Tools
Similar Threads for: Balancing forces on a bicycle wheel
Thread Forum Replies
Self balancing bicycle prototype using flywheel(reaction wheel) Mechanical Engineering 3
Bicycle wheel precession Classical Physics 2
two wheel non-balancing robot Mechanical Engineering 12
Rotating Bicycle Wheel Introductory Physics Homework 2
spinning bicycle wheel Introductory Physics Homework 1
