How much work done by a ball during an oblique collision?
The discussion revolves around the work done by a ball during an oblique collision with a surface. Participants explore the relationship between kinetic energy, the direction of forces, and the nature of work in the context of collisions, considering scenarios with and without friction, as well as the implications of wall deformation.
  • One participant questions whether only the kinetic energy associated with the normal velocity of the ball does work on the surface, noting the scalar nature of kinetic energy complicates this view.
  • Another participant explains that while kinetic energy is a scalar, energy can be transferred to the wall as heat during the collision, depending on various factors such as angle and speed.
  • A different participant clarifies that with no friction, the collision force is entirely perpendicular to the wall, suggesting that parallel motion can be ignored when calculating work done.
  • This participant also discusses the definition of work in terms of force and distance, stating that if the wall does not move, no work is done on it, but if it does move, work can be calculated based on the impulse applied during the collision.
  • A follow-up question is raised regarding the scenario where the wall deforms instead of moving, implying that the analysis may become more complex in that case.
Participants express differing views on the nature of kinetic energy and its role in work done during the collision. There is no consensus on how to approach the calculations, particularly regarding the implications of wall deformation.
Participants acknowledge the complexities involved in defining work and energy transfer during collisions, including assumptions about wall rigidity and the effects of friction, which remain unresolved.
sfensphan
Suppose I have a ball colliding with a surface at an oblique angle. I want to know what work will be done on the surface. Now, there is kinetic energy associated with the tangential and normal velocity of the ball. Can I say that the kinetic energy of the ball associated with the normal velocity is the only energy that does work on the surface? That makes sense to me, but I read that kinetic energy is a scalar, so can't be split up. I'm assuming that there is no friction. Any thoughts would be much appreciated.
Kinetic energy, like speed, can be increased or decreased. When the ball hits the wall, part of its energy is used to heat the wall and the ball up, assuming it just bounces off the wall. The ball has lost energy in this interaction and given it to the particles in the wall (heat energy or molecular kinetic energy). Finding out exactly how much energy you need to know the angle, speed, composition of the ball and wall, and many more values. If you know speed before, speed after, and ball weight you can loosely determine the amount of energy lost.
Since you are assuming no friction, it follows that there can be no component of the collision force that is parallel to the wall. The force must all be in the perpendicular direction. You are correct that this means that any motion of the ball parallel to the wall can be ignored in computing work done.
Although kinetic energy is a scalar, that does not mean that we cannot account for the total kinetic energy as partly due to motion in the x direction, partly due to motion in the y direction and partly due to motion in the z direction. The pythagorean theorem makes this work out nicely. We know that the square of total velocity is the sum of the squares of the velocity components in the x, y and z directions. So total energy is given by one half of mass times the sum of the squared velocity components in the x, y and z direction.
However, that's largely irrelevant to the question you posed. Recall the definition of work as the [vector dot] product of force applied multiplied by distance moved. If the wall is not moving that means that no work is done on the wall.
If the wall is moving then, in the absence of friction, the work done can be computed as distance moved by the wall (in the normal direction) multiplied by force applied by the ball (which is neccessarily in the normal direction).
We normally treat a collision as if it were instantaneous. So the force applied is infinite and the duration is zero. That means that the product of force applied times distance moved is technically undefined. However, it turns out that one can still solve such problems. The product of force applied times duration of collision is equal to the "impulse" applied to the ball. If you know how much the momentum of the ball changed then that is how much impulse was involved.
impulse(ball) = m(ball) * delta-v(ball)
By Newton's third law, the impulse applied to the wall is equal and opposite.
impulse(wall) = - m(ball) * delta-v(ball)
Recall the definition of impulse as force multiplied by time.
force-on-wall * collision-duration = - m(ball) * delta-v(ball).
Multiply both sides by the velocity of the wall
force-on-wall * collision-duration * velocity(wall) = -m (ball) * delta-v(ball) * velocity(wall)
But time times velocity gives a distance
force-on-wall * distance-moved-by-wall = - m(ball) * delta-v(ball) * velocity(wall)
And that's what we're after
work-done-on-wall = - m(ball) * delta-v(ball) * velocity(wall)
[There is some lack of rigor in the above, but it can be worked out rigorously and still gives the same result]
Thanks for the very detailed reply! I suspected that they would be separable (if that's the right word) for the case in which the wall is rigid but just didn't know what tool to use.
A followup if I could. What if the wall doesn't move but deforms? I don't think it would be as separable as before. Thanks again for your thoughts!
  • · Replies 77 ·
  • · Replies 23 ·
  • · Replies 60 ·
  • · Replies 55 ·
