| New Reply |
Can 2 light sources of different wavelenghts interfere one in another? |
Share Thread | Thread Tools |
| Dec16-12, 09:43 PM | #1 |
I'm asking because I was solving a double slit experiment problem in which the light was bichromatic (composed by 2 different colors, λ1 and λ2). What would we seen at the screen? Are there places where only one wavelenght is observed? Can the 2 wavelenghts interfere to create a third wavelenght?
Thank you John |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec17-12, 03:11 AM | #2 |
Recognitions:
Yes, the electric and magnetic fields just add up vectorially. The main practical problem in the detection is probably to maintain phase coherence between the two fields.
The creation of light with a different wavelength is possible at high field intensities ins so-called non-linear optical processes. E.g. the light of green laser diodes is often generated by frequency doubling of light in the near IR. |
| Dec17-12, 04:50 AM | #3 |
Regards, Noel. |
| Dec17-12, 11:38 AM | #4 |
Recognitions:
| Dec17-12, 12:33 PM | #5 |
Similarly, of you use broad spectrum light (white light, say) only the first dark stripe will be detectable but the pattern soon degenerates into blurry coloured fringes. But this, again, is just the superposition of a continuum of individual interference fringes of different wavelengths. A spatial interference pattern is only possible in a linear system when you can ensure that the signals received from two or more points in space have a constant phase relationship between them - so that you consistently get additive and subtractive interference over the whole cycle of the signal and in specific places. This only happens for signals of the same frequency - by definition. |
| Dec17-12, 03:56 PM | #6 |
Thanks Nugatory and Sophiecentaur. I understand the concepts / basics of the double-slit experiment, and why the configuration helps, but is this really a double-slit experiment (which I associate with the quantum wave / particle nature of light) or an experiment with two tightly confirned light paths / sources?
(I'm not questioning the experiment, just the reference to the double-slit experiment.) Regards, Noel. |
| Dec17-12, 04:12 PM | #7 |
Recognitions:
| Dec17-12, 04:16 PM | #8 |
Ah! Now I understand. Much appreciated Nugstory.
Regards, Noel. |
| Dec17-12, 04:23 PM | #9 |
If you want to predict what will happen with light then you only need to do the calculations for what would happen, classically, with radio waves. Adding the quantum factor is just standing up in a hammock afaics. Get the wave approach sorted out first and then, perhaps talk photons.
The wave approach says that two sources ('slits') will not produce a stationary spatial interference pattern unless they are coherent. This is the case, whether or not the two signals are a result of splitting one signal or they are generated independently. It would be a brave little Scientist who could predict a different result on quantum grounds. |
| Dec17-12, 04:29 PM | #10 |
Understood. Thanks Sophiecentaur.
Regards, Noel. |
| Dec20-12, 12:55 PM | #11 |
DrDu has the main point. To produce observable/detectable interference sources must be COHERENT. The slits provide 2 coherent sources even from an incoherent single source.
Slits are not needed if lasers are used because lasers produce coherent radiation Interference always occurs between waves of the same sort. Interference is a property of waves, not slits |
| Dec20-12, 02:16 PM | #12 |
I think you can also get stationary patterns if one frequency is a rational multiple of the other frequency. It will require fast photography and well controlled light sources to see, but it should be possible.
| New Reply |
| Thread Tools | |
Similar Threads for: Can 2 light sources of different wavelenghts interfere one in another?
| Thread | Forum | Replies | ||
| why doesn't a magnet interfere with light? | General Physics | 16 | ||
| Light waves through grating. Min and Max measurements of wavelenghts in nm | Introductory Physics Homework | 1 | ||
| sources of light | General Physics | 3 | ||
| Light sources | Atomic, Solid State, Comp. Physics | 2 | ||
| Light point sources | General Physics | 1 | ||
