New Reply
Determine position given linear and angular accelerations
Share Thread Thread Tools
Dec18-12, 10:12 AM   #1
Hello,
I would like to know how to calculate (x,y,z) in the inertial frame at any given time, t for a body I am testing. On the body, I have one instrument that can give me (u,v,w) in the body frame, another instrument to give (roll, pitch, yaw) in the body frame, and yet another instrument that can give both linear and angular accelerations (again in the body frame).
I am sampling at 100 Hz, but I want to determine position in the inertial frame from t=0 until the end of the test spot. I am assuming at t = 0 that the body is starting from the origin (0,0,0). At each new time step (i.e. t = t0 + 0.01) I get another data packet containing the information listed above.
Currently, we do a very crude method for determining position by integrating the linear velocity vector over the time step, but I'd like to improve upon this by starting with the linear and angular acceleration vector and integrate to get position.
Any help is greatly appreciated, thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Dec18-12, 01:51 PM   #2
While continuing to try to solve this problem, I was wondering instead if I should use my velocity and rotation relative to the body frame (u, v, w) and (roll, pitch, yaw) and translate the velocity frame back to the inertial frame using the Euler (3-2-1) direct cosine matrix?
Is this approach valid? If I apply the 3-2-1 direct cosine matrix, and multiple that by my velocity vector, doesn't this put my body velocity vector into the inertial frame?
New Reply
Tags
angular accerlation, calculate position, linear acceleration, position, time step
Thread Tools
Similar Threads for: Determine position given linear and angular accelerations
Thread Forum Replies
Angular and Linear Velocities to position Engineering, Comp Sci, & Technology Homework 1
Transformation of angular and linear velocities (to determine dynamics of an object) General Physics 0
Getting the magnitude of linear acceleration from angular position equation Introductory Physics Homework 6
Determining the angular and linear accelerations of a Rigid Body Classical Physics 0
Any idea about how determine body movement upun the accelerations? Calculus 3
