| New Reply |
Can one purchase depleted uranium? |
Share Thread |
| Dec21-12, 03:55 PM | #1 |
I'd like a small sphere of DU to illustrate mass, i.e. compare it to an equivalent (mass or radius) sphere of aluminum (say). I understand DU is used in airliners and yachts and it is safe so long as it is not aerosolized or particles are inhaled.
Are small samples of DU available commercially? |
| Dec21-12, 04:02 PM | #2 |
Mentor
| Dec21-12, 04:04 PM | #3 |
For CG adjustments, I believe.
| Dec21-12, 06:41 PM | #4 |
Admin
| Dec21-12, 07:25 PM | #5 |
Recognitions:
In the US, DU can be possessed only by someone who holds a license to do so.
The license is issued by the Nuclear Regulatory Commission (see this link: http://www.nrc.gov/reading-rm/doc-co...t040-0025.html) The holder is permitted to obtain DU only for certain specified purposes. |
| Dec21-12, 07:28 PM | #6 |
Recognitions:
http://news.bbc.co.uk/1/hi/sci/tech/593649.stm Of course an even better idea is to design planes so the the CG is in the right place without carrying excess weight around. |
| Dec21-12, 07:52 PM | #7 |
Mentor
| Dec21-12, 08:04 PM | #8 |
Admin
There are some exemptions from licensing, if the mass is below the limit for unimportant quantities.
http://www.nrc.gov/reading-rm/doc-co...t040-0013.html Best to read the entire 10 CFR 40, and either contact the NRC or Agreement State. http://www.nrc.gov/reading-rm/doc-co...s/cfr/part040/ One company indicates that it sells DU products. http://www.2spi.com/catalog/chem/dep...-products.html The idea of the license is to ensure proper care and disposition of the DU. As for Boeing counterweights: Depending on model and configuration, 21 to 31 counterweights in each tail assembly. Each aircraft has between 692 and 1059 pounds of DU. http://pbadupws.nrc.gov/docs/ML0321/ML032180089.pdf "Further, starting in 1981, customer airlines were provided tungsten replacement counterweights which may or may not have been installed in place of the original depleted uranium counterweights. At the worst case, the following estimate can be made based on the number of aircraft and spare depleted uranium counterweights sold. There were 550 aircraft produced between 1968 and 1981 utilizing depleted uranium counterweights. With spares, there is a possible world distribution of 15,000 weights (about 300 tons)." |
| Dec21-12, 11:55 PM | #9 |
A bit off topic, but Concorde had to shift fuel around to maintain the correct CoG for flight trim. Up to 33 tons of fuel was available in the trim tanks for this.
http://www.concordesst.com/fuelsys.html |
| Dec22-12, 03:58 PM | #10 |
Recognitions:
So you built the first prototype, weighed it, and then "balanced" it to put the CG where the aerodynamics guys had assumed it would be. The reason for using material as dense as possible was to make the counterweights small enough to "hide" inside the aircraft nose or tail. For operating the aircraft with different loading conditions etc, you can fine tune the CG by moving the fuel and/or cargo around. In principle its a "simple" problem - just get the mass and CG positions of all the parts and add them up. The trouble starts when you try to collect ALL the data, including the "non-obvious" bits like the fasteners (nuts, bolts, rvets, wiring clips, etc), flight deck equipment etc - for example there is about a quarter of a ton of paint on a B747! All these "odds and ends" might add up to 10% of the total mass of the structure. |
| Dec22-12, 05:00 PM | #11 |
Mentor
Very interesting, thanks Aleph. Yet again I learn something new here at the PF.
| Jan12-13, 01:21 AM | #12 |
www.goodfellow.com sells DU and other non-ferrous metals.
| New Reply |
Similar discussions for: Can one purchase depleted uranium?
| Thread | Forum | Replies | ||
| Depleted Uranium | General Physics | 20 | ||
| Depleted Uranium | Materials & Chemical Engineering | 1 | ||
| Depleted Uranium | Current Events | 19 | ||
| depleted uranium | Nuclear Engineering | 127 | ||
