| Thread Closed |
angular momentum of rod |
Share Thread | Thread Tools |
| Dec26-12, 11:02 AM | #1 |
What is the angular momentum of a rod rotating about one end (mass M and angular velocity ш),about its center of mass?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec26-12, 11:13 AM | #2 |
Mentor
| Dec26-12, 12:08 PM | #3 |
about one end
| Dec26-12, 01:06 PM | #4 |
A little research is in order.
http://scienceworld.wolfram.com/physics/ http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html "There is no need to know all the answers when you know how to find all the answers that have been found before." |
| Dec26-12, 01:13 PM | #5 |
But this is something fundamental,calculating angular momentum of a system about arbitary points in space.
| Dec26-12, 01:21 PM | #6 |
In the second link the 'bubbles' are hot links.
Navigate through "Mechanics", then "Rotation", then "Moment of Inertia". Click on "Common Forms" for Enlightenment! |
| Dec26-12, 01:27 PM | #7 |
Find the angular momentum of a differential length (dm*v*r) and integrate from r=0 to L.
| Dec26-12, 01:30 PM | #8 |
that you could get to following the links you were given in tadchem's response. |
| Dec26-12, 01:43 PM | #9 |
| Dec26-12, 01:52 PM | #10 |
hello kuyt, i think you should have a look at the angular momentum equation ie., L= r X P and v=rw. So, use r=l/2 where l=length of rod. hope that makes sense..
| Dec26-12, 02:04 PM | #11 |
No,it not that easy I guess.
P.S can anyone giveme the final answer(in terms of angular velocity,mass and length)and ofcourse the explanation,instead of links |
| Dec26-12, 02:06 PM | #12 |
It's (1/3)wmL^2 for angular speed w.
| Dec26-12, 02:09 PM | #13 |
^but that about one of the ends ,not com
| Dec26-12, 02:57 PM | #14 |
Recognitions:
Ah, so you're trying to find the angular momentum about the com, in a system where the rod is rotating about one end.
| Dec26-12, 03:02 PM | #15 |
yes
| Dec26-12, 03:54 PM | #16 |
Recognitions:
hmm. Tricky one. Well, I'm pretty sure that the whole point of saying the angular momentum "about a point" is equivalent to calculating the angular momentum, given that the origin is the point about which we want to find the angular momentum.
So I think the angular momentum about the COM is simply angular momentum, given that our origin is the COM. And in our original reference frame, the rod was rotating around the end. So in a reference frame where the COM stays at the origin, the angular momentum will simply be [tex] \omega \frac{mL^2}{12} [/tex] (in other words, same as what the angular momentum would be for a system where the rod is rotating around it's COM.) |
| Dec26-12, 06:02 PM | #17 |
Admin
The links provide helpful information.
Students are expected to demonstrate effort and show their work. We do not spoon feed students with answers. |
| Thread Closed |
| Tags |
| angular moment, centre of mass, hinged, rod, rotating |
| Thread Tools | |
Similar Threads for: angular momentum of rod
| Thread | Forum | Replies | ||
| angular momentum and conservation of angular momentum problem | Introductory Physics Homework | 0 | ||
| Angular momentum of rigid bodies,When to add (moment of inertia*angular velociy) | Introductory Physics Homework | 0 | ||
| Conserved angular momentum: finding angular velocities of drums as a function of time | Introductory Physics Homework | 2 | ||
| Physics Rotating Disk, Moment of Inertia, Angular Momentum, Angular Velocity | Introductory Physics Homework | 12 | ||
| Angular momentum and orbital angular momentum problems | Introductory Physics Homework | 3 | ||
