New Reply
Can someone explain this equation to me?
Share Thread Thread Tools
Dec26-12, 12:49 PM   #1
[tex]d=\left( \left. \frac { { d }x }{ { d }t } \right| _{ 0 } \right) t+\left( \left. \frac { { d }^{ 2 }x }{ { d }t^{ 2 } } \right| _{ 0 } \right) \frac { t^{ 2 } }{ 2 }[/tex]
is supposed to be the same as writing
[tex]d=vt+a\frac { t^{ 2 } }{ 2 }[/tex]
The first equation seems to use the definite integral, but there's no upper limit?
Furthermore, shouldn't it be the following?
[tex]d=\frac { { d }x }{ { d }t } t+\frac { { d^{ 2 } }x }{ { d }t^{ 2 } } \frac { t^{ 2 } }{ 2 }[/tex]
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec26-12, 01:02 PM   #2
I think it is about linear motion with constant acceleration, which is described by the equation:
[tex]\frac{{{d}^{2}}x\left( t \right)}{d{{t}^{2}}}=a[\tex]
where a is a constant. Integrate once (by changing the integration variable from t to τ) from τ = 0 to τ = t, to get:
Dec26-12, 01:04 PM   #3
Quote by cosmic dust View Post
Ingore this, I posted it by mistake, sorry. I'm texting the correct answer now,
Dec26-12, 01:15 PM   #4
Mentor
Quote by tahayassen View Post
Those aren't integrals. The notation
$$\left. \frac {dx}{dt} \right| _{0}$$
means "take the derivative of x(t) with respect to t, then evaluate it at t = 0." That is, it's simply a more complicated way of writing ##v_0##.
No, because dx/dt is the function v(t), and d2x/dt2 is the function a(t).
Dec26-12, 01:22 PM   #5
It is about linear motion with constant acceleration, which is described by the equation:
[tex]\frac{{{d}^{2}}x\left( t \right)}{d{{t}^{2}}}=a[/tex]
where "a" is a constant. Integrate once (by changing the integration variable from t to τ) from τ = 0 to τ = t, to get:
[tex]\int_{0}^{t}{\frac{{{d}^{2}}x\left( \tau \right)}{d{{\tau }^{2}}}d\tau }=at\Rightarrow \left. \frac{dx\left( \tau \right)}{d\tau } \right|_{0}^{t}=\frac{dx\left( t \right)}{dt}-{{\left. \frac{dx\left( \tau \right)}{d\tau } \right|}_{0}}=at[/tex]
Integrate again using the same limits to get:
[tex]\int_{0}^{t}{\left[ \frac{dx\left( \tau \right)}{d\tau }-{{\left. \frac{dx\left( t \right)}{dt} \right|}_{0}} \right]}d\tau =\frac{1}{2}a{{t}^{2}}\Rightarrow \left. x\left( \tau \right) \right|_{0}^{t}-{{\left. \frac{dx\left( t \right)}{dt} \right|}_{0}}t=\frac{1}{2}a{{t}^{2}}\Rightarrow x\left( t \right)-x\left( 0 \right)={{\left. \frac{dx\left( t \right)}{dt} \right|}_{0}}t+\frac{1}{2}a{{t}^{2}}[/tex]
Because of the constancy of the second derivative, you could set:
[tex]a={{\left. \frac{{{d}^{2}}x\left( t \right)}{d{{t}^{2}}} \right|}_{0}}[/tex]
(alternatively, you could start by the equation [itex]\frac{{{d}^{3}}x\left( t \right)}{d{{t}^{3}}}=0[/itex] , integrate three times and get to the same result). Also you can define: [itex]x\left( t \right)-x\left( 0 \right)=d\left( t \right)[/itex] so you get the equation:
[tex]d\left( t \right)={{\left. \frac{dx\left( t \right)}{dt} \right|}_{0}}t+\frac{1}{2}{{\left. \frac{{{d}^{2}}x\left( t \right)}{d{{t}^{2}}} \right|}_{0}}{{t}^{2}}[/tex]
Dec26-12, 01:23 PM   #6
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Well, let the rest of us know!
tahayassen, there is no integral in the equation. That is saying that d (probably "distance") is equal to the "first derivative evaluated at t= 0" times t plus "the second derivative evaluated at t= 0" times t squared. That would be the distance covered in time t with initial speed the speed at time t= 0 and constant acceleration equal to the acceleration at t= 0.
The difference between what you give initially and your suggestion is that the acceleration is assumed to always be the acceleration of x at t= 0, thus a constant.
Dec26-12, 01:26 PM   #7
No.
The reason is that dx/dt and d^2 x/dx^2 may be changing with time. By placing the subscripts after the parentheses, on is implying that the derivative itself isn't changing in time. The subscript is defined as meaning that the derivative is evaluated only at t=0.
Dec26-12, 02:10 PM   #8
Kind of skimmed through the article, but I didn't see anyone put this very plainly because apparently I have problems with reading (edit in red).
Summarizing in more vernacular terms:
What is the first derivative of x (position) with respect to time? What is the second derivative of x with respect to time?
Velocity and acceleration, respectively. I see no need for integrals. We are evaluating these values at the point where no time has passed. Thus, I think it would be more appropriate to write [itex]d = v_0 t + a_0 \frac{t^2}{2}[/itex] because we are using the initial velocity and initial acceleration.
Dec26-12, 09:51 PM   #9
Thanks guys!
@cosmic dust: Why did you change the variable from t to τ? Which one of the two represents time? What does the other represent?
Dec27-12, 12:32 AM   #10
Mentor
To avoid confusion between the integration variable and the upper limit which you substitute during the final step of the integration process. Other common notations are to use t' for the integration variable and t for the upper limit, or to use t for the integration variable and tf for the upper limit (in that case you often see ti or t0 for the lower limit, which can be nonzero in general).
Both of them represent times, but different ones. In cosmic dust's notation, τ is the "generic" time at any instant during the object's motion. t is the time at the end of the time period that we're integrating over, which extends from τ = 0 to τ = t.
New Reply
Thread Tools
Similar Threads for: Can someone explain this equation to me?
Thread Forum Replies
Can someone explain this equation? Introductory Physics Homework 20
Explain this equation Beyond the Standard Model 5
How do you explain this, Equation? Differential Equations 3
Can somebody explain to me this integrodifferential equation? Differential Equations 0
Can someone explain the Schrödinger equation? Quantum Physics 4
