New Reply
How Do You Calculate Buoyant Energy?
Share Thread Thread Tools
Dec27-12, 02:23 PM   #1
Buoyancy is an artifact of gravity that moves mass up away from the center of the earth in a fluid whenever the specific gravity of the object is less than the surrounding fluid.
Buoyant Force is calculable.
Gravitational Potential Energy is calculated by the formula: mgh
Is Buoyant Potential Energy calculated mg'h?
Here is how I have calculated it so far;
mass = 100,000 kg
height or depth = 100 meters
g' = 1 - (1000 / 1028) = 1 - 0.97276265 = 0.02723735
(The density of the solid object is 1,000 kg/m. The density of the fluid is 1,028 kg/m)
By this calculation the Buoyant Potential Energy would be 272,373.54 Joules
Is this correct? Could it be improved on?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Dec27-12, 03:02 PM   #2
Mentor
Quote by genergy View Post
mass = 100,000 kg
The units of density would be kg/m^3, not kg/m as you show.
BTW, would there be more "bouyant energy" stored if you pushed a solid object down to a depth, or pushed an air-filled object down, where the object shrinks in size as it gets to greater pressures at lower depths?
Dec27-12, 03:08 PM   #3
mfb
Mentor
You can define g' such that the potential energy is mg'h, but this would be an odd definition as the density of the object would contribute to g'. I would change m to m' which is the difference of the mass of the object and the corresponding mass of water. If you just know the density, but not the total mass or volume of the object, all you can calculate is an energy density: ##\frac{E}{V}=\rho'gh = (\rho_{object}-\rho_{water})gh## where ρ are density values.
Dec27-12, 04:17 PM   #4
Quote by berkeman View Post
I did forget to put cubic meters. I don't think that there would be more energy but there might be less area to cause viscous drag as the object accelerated upwards.
Dec27-12, 04:23 PM   #5
Mentor
One thing I've observed (as a scuba diver) is that if you inflate a baloon at depth and release it, it accelerates very slowly at first, and as it grows in size it accelerates faster. You are right that there is more drag as it gets bigger (and goes faster), but the added bouyant lift from the larger displaced water volume seems to overpower that.
Aside -- it is *very* disconcerting when you are in trouble and have to pull your Bouyancy Compensator (BC) vest's ripcord, to inflate it to take you to the surface -- if you are at any depth, you barely start to accelerate to the surface at all. As you rise, you go faster and faster, which is finally reassuring.
Dec27-12, 04:32 PM   #6
Quote by mfb View Post
Here is another way that I tried where I copied the formula from the web;
Net Gravitational Acceleration g' -0.315072129 m/s2
1-p'/p -0.032128514 m/s2
Object Density p 996 kg/m3
Fluid Density p' 1,028 kg/m3
Buoyant Force Fb 1,013,473 N
The idea was that I could back in F=MA and multiply the Buoyant Force * g' * the mass and come up with the energy potential. Should I put in m' - the differential mass - instead of the mass?
Dec27-12, 04:42 PM   #7
This was the last attempt that I made before posting the thread. I think that I am applying what you said but I am not quite sure. Does this method accomplish the Energy Density method of calculating Buoyant energy?
Buoyant Force Calculator
Gravity ("g") Force 9.80662 m/s2
Mass 100,129 kg
Force 981,925 N
Density 996 kg/m3
Submerged Volume 101 m3
Volume 101 m3
Fluid (Seawater) Density 1,028 kg/m3
Buoyant Force 1,013,473 N
Net Buoyant Force Upwards 31,548 N
Buoyant Path Distance 244.8 m
Buoyant Joules (N m) 7,722,903 J
Buoyant Potential Energy 2.15 kWh
Buoyant Power 198 kW
Dec28-12, 09:21 AM   #8
mfb
Mentor
Looks right, but I did not check the numbers in a calculator.
You need some time (for those 244.8m) or velocity to calculate a power.
Dec28-12, 09:46 AM   #9
I used 39 seconds.
Does that seem good?
Dec28-12, 10:22 AM   #10
mfb
Mentor
Depends on the setup. And if you let that thing float upwards, it depends on the water resistance, which depends on the shape of the object.
Dec28-12, 03:28 PM   #11
I used the calculation off of this page at Hyper Physics;
http://hyperphysics.phy-astr.gsu.edu/hbase/lindrg.html
I plugged the variables into Excel and ran the formula. Now that it is in Excel, (theoretically if I did not make any mistakes copying) I can adjust the size of the radius and the density.
Is this page a standard or are there different variations of how to estimate the drag on a sphere ascending by buoyancy? I have heard of Reynolds Number, Laminar Flow, Cavitation, and a lot more variables: very complex and over my head calculations. But, I am hoping that this gives me a good ballpark estimate.
Dec28-12, 04:23 PM   #12
mfb
Mentor
I am quite sure that an object with that size and velocity in water will not follow Stoke's law.
Dec28-12, 05:28 PM   #13
I have been doing some other work on the more advanced equations. I was hoping to get a "Ballpark" estimate of the acceleration. Do you think that the Reynolds Number will be out of line or is there some other reason that I cannot use this as a First Estimate?
Dec29-12, 01:54 AM   #14
That is, if you use h=0 as datum for calculating potential energy. In general, for a sufficiently small mass (call it a point mass) immersed in a liquid, the energy density at the point is [itex](\rho_{object}h +\rho_{liquid}x)g [/itex], where x is the distance from the datum, -h in your case.
Dec29-12, 09:12 AM   #15
mfb
Mentor
Stoke's law in water is useful for falling/rising objects in the mm-range.
There are formulas for turbulent flow, with force proportional to the velocity squared. You can solve this for the equilibrium velocity.
Dec29-12, 01:16 PM   #16
Ouch! I had no idea of Stoke's Law limitation! Can you please direct me to some specific formulas?
Dec31-12, 01:26 PM   #17
Of course, it is even more disconcerting because you know the more agitated that you get the more oxygen you burn.
New Reply
Tags
buoyancy, buoyant, energy, potential
Thread Tools
Similar Threads for: How Do You Calculate Buoyant Energy?
Thread Forum Replies
help finding potential energy of submerged buoyant object Classical Physics 6
Calculate most probable energy from Maxwell-Boltzmann distribution of energy Advanced Physics Homework 13
Calculate Change of Energy of an Electron Changing Energy Levels in a Atom in Calculu Calculus & Beyond Homework 3
Calculate the magnitude of buoyant force Introductory Physics Homework 1
Buoyant Lift Creates Useful Energy? General Physics 17
