How Do You Calculate Buoyant Energy?
  • Context: Undergrad
  • Thread starter Thread starter genergy
    Buoyant Energy
The discussion revolves around the calculation of buoyant energy, exploring the concept of buoyant potential energy in relation to gravitational potential energy. Participants examine various formulas, assumptions, and methods for calculating buoyant energy, including the effects of object density and fluid density. The scope includes theoretical considerations, mathematical reasoning, and practical applications related to buoyancy in fluids.
  • Some participants propose that buoyant potential energy can be calculated using a modified gravitational potential energy formula, suggesting the use of a different gravitational acceleration term, g'.
  • Others argue that the definition of g' is problematic as it depends on the density of the object, proposing instead to use the differential mass of the object compared to the fluid.
  • A participant presents a calculation for buoyant potential energy based on specific parameters, questioning the correctness and potential improvements of their method.
  • Some participants discuss the implications of pushing different types of objects (solid vs. air-filled) to depth, raising questions about the buoyant energy stored and the effects of pressure on object size.
  • There are discussions about the relationship between buoyant force, energy density, and the calculations involving forces and accelerations, with suggestions to consider the differential mass in calculations.
  • Participants share personal experiences related to buoyancy, such as observations from scuba diving, which inform their understanding of buoyant forces and energy dynamics.
  • Concerns are raised about the applicability of certain laws (like Stokes' law) to the scenarios discussed, particularly regarding the size and velocity of objects in water.
  • Some participants express uncertainty about the complexity of drag calculations and the relevance of various factors like Reynolds number and flow conditions.
Participants do not reach a consensus on the correct method for calculating buoyant energy, with multiple competing views on the definitions and formulas used. There is ongoing debate about the appropriate variables and assumptions in the calculations.
Limitations include the dependence on specific definitions of buoyant energy and gravitational acceleration, as well as unresolved mathematical steps in the proposed calculations. The discussion also highlights the complexity of drag forces and their influence on buoyant motion.
This discussion may be of interest to individuals studying fluid dynamics, buoyancy, or related fields in physics and engineering, as well as those engaged in practical applications such as diving or underwater engineering.
genergy
Buoyancy is an artifact of gravity that moves mass up away from the center of the Earth in a fluid whenever the specific gravity of the object is less than the surrounding fluid.
Buoyant Force is calculable.
Gravitational Potential Energy is calculated by the formula: mgh
Is Buoyant Potential Energy calculated mg'h?
Here is how I have calculated it so far;
mass = 100,000 kg
height or depth = 100 meters
g' = 1 - (1000 / 1028) = 1 - 0.97276265 = 0.02723735
(The density of the solid object is 1,000 kg/m. The density of the fluid is 1,028 kg/m)
By this calculation the Buoyant Potential Energy would be 272,373.54 Joules
Is this correct? Could it be improved on?
mass = 100,000 kg
The units of density would be kg/m^3, not kg/m as you show.
BTW, would there be more "buoyant energy" stored if you pushed a solid object down to a depth, or pushed an air-filled object down, where the object shrinks in size as it gets to greater pressures at lower depths?
You can define g' such that the potential energy is mg'h, but this would be an odd definition as the density of the object would contribute to g'. I would change m to m' which is the difference of the mass of the object and the corresponding mass of water. If you just know the density, but not the total mass or volume of the object, all you can calculate is an energy density: ##\frac{E}{V}=\rho'gh = (\rho_{object}-\rho_{water})gh## where ρ are density values.
I did forget to put cubic meters. I don't think that there would be more energy but there might be less area to cause viscous drag as the object accelerated upwards.
One thing I've observed (as a scuba diver) is that if you inflate a balloon at depth and release it, it accelerates very slowly at first, and as it grows in size it accelerates faster. You are right that there is more drag as it gets bigger (and goes faster), but the added buoyant lift from the larger displaced water volume seems to overpower that.
Aside -- it is *very* disconcerting when you are in trouble and have to pull your Bouyancy Compensator (BC) vest's ripcord, to inflate it to take you to the surface -- if you are at any depth, you barely start to accelerate to the surface at all. As you rise, you go faster and faster, which is finally reassuring.
Here is another way that I tried where I copied the formula from the web;
Net Gravitational Acceleration g' -0.315072129 m/s2
1-p'/p -0.032128514 m/s2
Object Density p 996 kg/m3
Fluid Density p' 1,028 kg/m3
Buoyant Force Fb 1,013,473 N
The idea was that I could back in F=MA and multiply the Buoyant Force * g' * the mass and come up with the energy potential. Should I put in m' - the differential mass - instead of the mass?
This was the last attempt that I made before posting the thread. I think that I am applying what you said but I am not quite sure. Does this method accomplish the Energy Density method of calculating Buoyant energy?
Buoyant Force Calculator
Gravity ("g") Force 9.80662 m/s2
Mass 100,129 kg
Force 981,925 N
Density 996 kg/m3
Submerged Volume 101 m3
Volume 101 m3
Fluid (Seawater) Density 1,028 kg/m3
Buoyant Force 1,013,473 N
Net Buoyant Force Upwards 31,548 N
Buoyant Path Distance 244.8 m
Buoyant Joules (N m) 7,722,903 J
Buoyant Potential Energy 2.15 kWh
Buoyant Power 198 kW
Looks right, but I did not check the numbers in a calculator.
You need some time (for those 244.8m) or velocity to calculate a power.
I used 39 seconds.
Does that seem good?
Depends on the setup. And if you let that thing float upwards, it depends on the water resistance, which depends on the shape of the object.
I used the calculation off of this page at Hyper Physics;
http://hyperphysics.phy-astr.gsu.edu/hbase/lindrg.html
I plugged the variables into Excel and ran the formula. Now that it is in Excel, (theoretically if I did not make any mistakes copying) I can adjust the size of the radius and the density.
Is this page a standard or are there different variations of how to estimate the drag on a sphere ascending by buoyancy? I have heard of Reynolds Number, Laminar Flow, Cavitation, and a lot more variables: very complex and over my head calculations. But, I am hoping that this gives me a good ballpark estimate.
I am quite sure that an object with that size and velocity in water will not follow Stoke's law.
I have been doing some other work on the more advanced equations. I was hoping to get a "Ballpark" estimate of the acceleration. Do you think that the Reynolds Number will be out of line or is there some other reason that I cannot use this as a First Estimate?
That is, if you use h=0 as datum for calculating potential energy. In general, for a sufficiently small mass (call it a point mass) immersed in a liquid, the energy density at the point is [itex](\rho_{object}h +\rho_{liquid}x)g[/itex], where x is the distance from the datum, -h in your case.
Stoke's law in water is useful for falling/rising objects in the mm-range.
There are formulas for turbulent flow, with force proportional to the velocity squared. You can solve this for the equilibrium velocity.
Ouch! I had no idea of Stoke's Law limitation! Can you please direct me to some specific formulas?
Of course, it is even more disconcerting because you know the more agitated that you get the more oxygen you burn.
11K
13K
  • · Replies 54 ·
  • · Replies 138 ·
9K
