New Reply
Law of gravitation
Share Thread Thread Tools
Jan7-13, 12:59 PM   #1
Law of gravitation
I was going through a site which tells:
F=G.m1.m2r^2
Also
F=-G.m.m/r^2.
Can it be written?
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan7-13, 01:04 PM   #2
Mentor
Quote by shounakbhatta View Post
F=G.m1.m2r^2
Also
F=-G.m.m/r^2.
Can it be written?
Thanks.
The first version makes no sense.
See: Newton's law of universal gravitation
Jan7-13, 01:11 PM   #3
Sorry,
F=G.m1.m2/r^2
Can it be written:
F=-G.m.m/r^2.
Jan7-13, 01:35 PM   #4
Mentor
Law of gravitation
Yes, if and only if m1=m2=m.
EDIT: actually I just noticed the minus sign. You have to be careful that gravity is always attractive, never repulsive.
Jan7-13, 01:36 PM   #5
Mentor
Sorry,
F=G.m1.m2/r^2
Can it be written:
F=-G.m.m/r^2.
Sometimes when writing the force as a vector expression a minus sign is used to indicate that it's an attractive force:
[tex]\vec{F} = - \frac{G m_1 m_2}{r^2} \hat{r}[/tex]
Where [itex]\vec{r}[/itex] is the position vector of m_2 with respect to m_1 and [itex]\vec{F}[/itex] is the gravitational force on m_2 due to m_1.
See: Vector form
Jan7-13, 02:57 PM   #6
Ok, so writing force as a vector we use minus.
As gravity is always attractive, so can we always use minus sign and don't use minus sign when any force is repulsive, like electric?
Jan8-13, 02:10 PM   #7
Recognitions:
Homework Helper Homework Help
yep. As Doc Al said, the important part is if on the left-hand side, we have the force on 1 due to 2, and if on the right hand side we have the position of 1 with respect to 2, then we need the minus sign for an attractive force. (And this is the most common way it is written). And yes, for a repulsive force, it will be positive. (this is automatically taken into account by multiplying the two charges together in the case of electric force).
Jan9-13, 01:27 AM   #8
Ok. Thank you very much.
Jan9-13, 07:13 AM   #9
F=G.m1.m2r^2
Yes, as what with the others have said, we use a minus sign to indicate (an attractive) force as a vector.
So the equation, with R2 proportional to Force, should and would be:
F = G M1M2 r-2
So that R-2 would mean to be inversely proportional to the Force (F), equal to the second equation in your original post.
The equation is derived from the Inverse Square Law: The greater the (square) distance between objects/masses, the lesser the force; and vice versa.
New Reply
Thread Tools
Similar Threads for: Law of gravitation
Thread Forum Replies
While reading gravitation chapter I Classical Physics 3
Gravitation Introductory Physics Homework 0
more on gravitation Introductory Physics Homework 3
SHM and Gravitation Advanced Physics Homework 3
Gravitation Introductory Physics Learning Materials 0
