New Reply
Throttling Ideal Gas
Share Thread Thread Tools
Jan10-13, 04:38 AM   #1
A quick question about throttling:
I've read that for an ideal gas, if you force it through a capillary into a vacuum and allow it to equilibrate, it will experience no temperature change. I was wondering if this is correct, and if anything changes when you're forcing it through with a piston for example.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Jan11-13, 11:53 AM   #3
Even with an ideal gas, this sort of thought experiment is very misleading and about impossible to make in practice...
First, the gas would take the temperature of the capillary.
Then, the gas that at some time remains in the bottle pushes the gas that goes out, gives a work, and loses internal heat. It cools down, while the flowing gas receives some work that it may transform into internal heat, depending on the experiment, or into kinetic energy, or into work against the external pressure.
It's only after a very long time that the gas may regain some form of equilibrium - between the part flown first out and the part flown last - that the temperature is uniform, and then, with a ideal gas, you may observe the same temperature as before the expansion.
So it's much more a question of setup and time than of the gas being ideal. In two words: be careful.
New Reply
Tags
thermodynamics
Thread Tools
Similar Threads for: Throttling Ideal Gas
Thread Forum Replies
throttling in thermodynamics Mechanical Engineering 2
Throttling a Gas Cylinder Materials & Chemical Engineering 7
air throttling (real gas) Introductory Physics Homework 0
when flowing fluid passes through throttling there is a drop in Mechanical Engineering 5
Throttling Process Engineering Systems & Design 7
