| New Reply |
Centre of Gravity and Centre of Mass |
Share Thread |
| Jan16-13, 12:38 PM | #1 |
Hey folks,
I was doing some moments problems the other day, and I started considering centre of mass and centre of gravity and have gotten myself rather unsure. My textbook defines centre of mass as "the point through which a single force has no turning effect", which I have an intuitive grasp of. However, it then goes on to talk about how something will topple if the centre of MASS lies outside the base. But in previous studies, the reason for toppling was given as the line of action of weight lying outside the base. But surely that corresponds to the centre of GRAVITY lying outside the base... This has led to me thinking about when a body lies in a non uniform gravitational field and hence the centre of gravity is not in the same place as the centre of mass. I understand the centre of gravity as the point from which the weight can be thought to act. So If you have a body in the aforementioned situation, surely it should rotate as the CoG would cause a moment about the Centre of Mass. Would this body then rotate about the CoM? I was wondering if someone could define centre of gravity and explain the difference between the two so that i can be sure, and also allowing me to answer some of my puzzling issues. Many thanks, Dom |
| Jan16-13, 12:46 PM | #2 |
I don't think there is a difference between the two. Your center of mass should be the same as your center of gravity.
| Jan16-13, 12:59 PM | #4 |
| Jan16-13, 01:04 PM | #5 |
note: I know this doesn't address difference between CG and CM, but I don't think that is an integral part of your confusion. My apologies if I'm wrong. |
| Jan16-13, 01:24 PM | #6 |
| Jan16-13, 01:35 PM | #7 |
Mentor
| Jan16-13, 01:45 PM | #8 |
| Jan16-13, 01:49 PM | #9 |
Mentor
The CoG is often defined as a point about which there is no torque due to gravity, which as long as the gravitational field is uniform is the same as the center of mass. |
| Jan16-13, 04:22 PM | #10 |
Just to reinforce what Doc Al has said, Imagine a body floating free in space (no gravity). If you apply a force (eg a rocket thrust) on a line through the centre of mass the body will be driven along that line without spinning. If you apply the same thrust off this line it will not only drive the mass forwards it will also cause it to start spinning. |
| Jan16-13, 06:11 PM | #11 |
Recognitions:
The COG is defined from the force distribution caused by gravity, i.e. $$\int_V \rho(\mathbf r)g(\mathbf r) \mathbf r\,dv\; \Big/\! \int_V \rho(\mathbf r)g(\mathbf r) \,dv$$ If ##g(\mathbf r)## is independent of the position ##\mathbf r##, the two are equal. The most common "practical" case where the two definitions are not equal is when working in a rotating (non-inertial) coordinate system, though I won't complain if you object to using the word "gravity" in that situation. |
| Jan16-13, 06:14 PM | #12 |
| Jan16-13, 06:48 PM | #13 |
Recognitions:
http://en.wikipedia.org/wiki/Centers...ity_in_a_field |
| New Reply |
Similar Threads for: Centre of Gravity and Centre of Mass
| Thread | Forum | Replies | ||
| centre of mass and centre of gravity | Classical Physics | 3 | ||
| centroid,centre of mass and centre of gravity | Introductory Physics Homework | 5 | ||
| Question about centre of mass and load centre of gravity | General Engineering | 3 | ||
| centre of mass vs. centre of gravity | Classical Physics | 1 | ||
| HELP : Centre of mass and Centre of gravity | Introductory Physics Homework | 5 | ||
