Register to reply
Angular momentum vectors and frisbees
by mperkins01
Tags: angular momentum, frisbees
Share this thread:
mperkins01
#1
Jan16-13, 05:38 PM
P: 1
While working on shooting mechanisms for the 2013 FIRST Robotics Competition, our mentoring scientist noted that the direction of the angular momentum vector pointed down for our prototype shooter. So now we're debating whether the vector points up or down matters for the flight of the frisbee. I argue that it must be the same, since a left handed person can throw as well as a right handed person.
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
haruspex
#2
Jan16-13, 06:38 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,645
Which way a spin vector points is a matter of convention. See http://en.wikipedia.org/wiki/Right-hand_rule. As far as the maths is concerned, it doesn't matter which way you choose as long as you are consistent. For the flight of a Frisbee or a gyroscope, there are are two spin vectors of interest: its angular momentum and an applied torque. Using the same convention for each of those (and using the convention for direction of cross-product that matches the order in the equation) produces a resultant precession in the same spin convention.
rcgldr
#3
Jan16-13, 07:36 PM
HW Helper
P: 7,033
Quote Quote by mperkins01 View Post
or a right handed person can throw with an "outside" spin to get the same spin as an "inside" left handed throw.
For a frisbee, there's a downwards pitching torque during flight (due to center of lift offset from center of mass) that results in precession to the left or right. An Aerobie, which is a flying ring, is designed to eliminate nearly all of this pitching torque which mostly eliminates the precession issue.
Register to reply
Related Discussions
Angular momentum and conservation of angular momentum problem Introductory Physics Homework 0
Are angular displacement, angular velocity, and angular acceleration, vectors? Classical Physics 5
Angular velocity and angular momentum vectors Advanced Physics Homework 0
Vectors and angular momentum Calculus & Beyond Homework 4
Angular momentum vectors Introductory Physics Homework 1
