New Reply
What exactly is centrifugal force
Share Thread Thread Tools
Jan28-13, 12:51 PM   #1
I think that there is no such thing as centrifugal force .
Am I right ? is this force fictitious ?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan28-13, 01:09 PM   #2
For some systems that are not in equilibrium ie moving, D'Alembert introduced a method of applying a fictitious force to bring the system to equilibrium (rest). The equations of equilibrium could then be employed to solve the system. These equations then included the fictitious force.
Centrifugal force is just such a force applied to objects executing circular motion.
Jan28-13, 01:11 PM   #3
What is the source of this force ?
For example, in gravitational circular motion, where does this force originate from ?
Jan28-13, 01:14 PM   #4
It doesn't exist.
That is why it is fictitious.
However we can do the maths as though it did exist.
It is a mathematical trick.
The modern alternative is to use Newton's Laws of Motion, which I think came after D'Alembert, but I will check that.
Jan28-13, 01:31 PM   #5
If something as a source of centrifugal force exists, then I think it is the inertia.
Jan28-13, 01:44 PM   #6
Recognitions:
Homework Helper Homework Help
Quote by hms.tech View Post
I think that there is no such thing as centrifugal force. ... is this force fictitious ?
Depends on how you're using the term centrifucal force. There's the fictitious centrifugal force in a rotating frame. A less common (for physicists) usage is "reactive centrifugal force", which is part of a pair of Newton third law forces: say a string exerts a centripetal force on an object, then the object exerts a reactive outwards force on the string. Note that this "reactive centrifugal force" is not exerted on the object itself, but on the string. In a rotating frame, the fictitious forces, centripetal and coriolis (and euler if there is angular acceleration of the frame) all appear to act on the object. Wiki articles:
http://en.wikipedia.org/wiki/Reactive_centrifugal_force
http://en.wikipedia.org/wiki/Centrif...e_(fictitious)
http://en.wikipedia.org/wiki/Rotating_frame
Jan28-13, 02:20 PM   #7
Quote by Studiot View Post
It doesn't exist.
All forces are just mathematical models invented by humans.
"Fictitious force" is just an unfortunate name choice. It gives people the wrong idea that some forces are more "real" than others. But that is just philosophy, irrelevant to physics. That is why I prefer the terms "inertial forces" and "interaction forces".
Jan28-13, 02:25 PM   #8
Quote by A.T. View Post
Yes, I read this word "inertial" a lot on the Wikipedia link provided by rcgldr.
Can you explain this notion ?
Jan28-13, 02:40 PM   #9
hms.tech
Before you get confusing explanations as to the different ways of regards motion under a central force or circular motion perhaps you would tell us what your course says ie which approach they take. Your exams will be based on this.
Jan28-13, 02:57 PM   #10
hms.tech
Centripetal and centrifugal forces
I couldn't find the term centrifugal force in any of my physics books, hence I checked out PF. Can you provide some links (non Wikipedia) about centrifugal force .
Here is what I understand about this force :
I think this term was self created by humans for their own better understanding of the "motion" of objects in circular orbit.
We, the modern physicists would call it nothing but a consequence of the fact that any object undergoing circular motion tends to move in a straight line (tangential to its path) . So it can be thought of as "inertia" , but I would stick to my claim that this force is non existent.
Jan28-13, 03:01 PM   #11
Recognitions:
Yes, I read this word "inertial" a lot on the Wikipedia link provided by rcgldr. Can you explain this notion ?
An "inertial" frame of reference means the frame of reference is not accelerating (no linear acceleration and no rotation). Newton's laws of physics apply in an inertial frame without any modification.
If the frame was accelerating, such as a rocket in space, then to an observer inside the rocket, there would be an apparent force on any object within the spacecraft, similar to gravity on earth.
The wiki article on this goes into more detail:
http://en.wikipedia.org/wiki/Inertia...e_of_reference
I couldn't find the term centrifugal force in any of my physics books, hence I checked out PF. Can you provide some links (non Wikipedia) about centrifugal force.
http://www.answers.com/topic/centrifugal-force
In your diagram of the car in a turn, there is a Newton third law pair of forces, an inwards centripetal force exerted by the road onto the car, and an equal in magnitude but opposing outwards reaction force that the car applies to the road. That outwards force is real, the issue for some people is using the term "reactive centrifugal force" to describe that outwards force that the car exerts to the road.
Jan28-13, 03:10 PM   #12
A more simple example might serve to make this clear:
consider a train that is accelerating with acceleration a. You are on this train and you drop a ball. The only force due to a physical interaction acting on the ball is that of gravity which is due to the ball's interaction with the Earth.
However, you see the ball accelerating away from you with the same magnitude of acceleration as that of the acceleration of the train. Thus if we consider the acceleration of your reference frame (keep in mind that since you're measuring the motion of the ball with your position as the origin, you are at rest in your reference frame) as the source of a force on the ball, it applies a force of magnitude ma, where m is the mass of the ball. This force isn't due to any physical interaction that you can observe, that's why we call it fictitious. I agree that calling it fictitious is confusing and that inertial is less confusing and also an apt name in that the magnitude of the force is proportional to the mass of the object
A similar thing happens when you're in a rotating reference frame (for instance say someone does this while on a merry go round) except that now this fictitious force is directed outwards from the center of the merry go round. This type of fictious force due to being on an accelerated (or noninertial reference frame) is called centrifugal.
A centripetal force is the net force in the radial direction due to real forces and is generally talked about in an inertial or non-accelerated reference frame. Hope that clears it up a bit
Jan28-13, 03:40 PM   #13
Look at post#9 of this thread.
http://www.physicsforums.com/showthr...trifugal+force
It puts what I said in post#2 here into equations.
Jan28-13, 04:50 PM   #14
http://en.wikipedia.org/wiki/Fictitious_force
In short: Newton based his laws of motion for inertial reference frames on interaction forces. To generalize some of the laws so they apply to non-inertial frames inertial forces were introduced.
Jan28-13, 06:23 PM   #15
Gosh I'm glad I didn't meet that wiki as my first introduction to centrifugal force.
It's one saving grace is that at the very bottom it refers to the D'alembert's principle of inertia wiki.
That is much more digestible.
http://en.wikipedia.org/wiki/D%27Alembert%27s_principle
Look towards the end of the much shorter page.
Jan28-13, 08:53 PM   #16
Here's a mathematical way to think about fictitious forces.
Suppose you have a velocity vector [itex]\stackrel{\rightarrow}{U}[/itex] which is constant (no forces acting on it). That means
[itex] \dfrac{d}{dt}\stackrel{\rightarrow}{U} = 0 [/itex]
Now, this is a vector equation. It's common for people to denote vectors by ordered pairs:
[itex]\stackrel{\rightarrow}{U} = (U^x, U^y)[/itex], where [itex]U^x = \dfrac{dx}{dt}[/itex] and [itex]U^y = \dfrac{dy}{dt}[/itex].
But that's actually a BAD notation, because what it really means to write a vector as components is that we've chosen certain vectors called basis vectors, and we've expressed [itex]\stackrel{\rightarrow}{U}[/itex] as a combination of those basis vectors. So a better way to write it is
[itex]\stackrel{\rightarrow}{U} = U^x\ \hat{e_x} + U^y\ \hat{e_y}[/itex]
When you write it this way, you can see that
[itex] \dfrac{d}{dt}\stackrel{\rightarrow}{U} = \dfrac{dU^x}{dt} \hat{e_x} + U^x \dfrac{d \hat{e_x}}{dt} + \dfrac{dU^y}{dt} \hat{e_y} + U^y \dfrac{d \hat{e_y}}{dt}[/itex]
Of course, the most important fact about Cartesian coordinates is that the basis vectors are constant. So the terms [itex]\dfrac{d\hat{e_x}}{dt}[/itex] and [itex]\dfrac{d\hat{e_y}}{dt}[/itex] are both zero.
But if you switch to polar coordinates [itex]r,\theta[/itex], it's no longer the case that the basis vectors are constant. So you get additional terms having to do with the rate of change of the basis vectors. Those additional terms are the "fictitious forces".
I'm going to spare the details, but it turns out to be, in polar coordinates:
[itex] \dfrac{d}{dt}\stackrel{\rightarrow}{U} = (\dfrac{dU^r}{dt} - r (U^\theta)^2) \hat{e_r} + (\dfrac{dU^\theta}{dt} + \dfrac{2}{r} U^r U^\theta) \hat{e_\theta}[/itex]
where [itex]U^r = \dfrac{dr}{dt}[/itex] and [itex]U^\theta = \dfrac{d \theta}{dt}[/itex].
So, if there are no forces acting on an object, then [itex]\stackrel{\rightarrow}{U}[/itex] will be constant, but that doesn't mean the components will be constant. Instead, the components will obey:
[itex]\dfrac{dU^r}{dt} = r (U^\theta)^2[/itex]
[itex]\dfrac{dU^\theta}{dt} = - \dfrac{2}{r} U^r U^\theta[/itex]
So it seems that there are "fictitious" forces acting on the object, causing the components of the velocity to change.
Nonconstant basis vectors give rise to nonconstant components of velocity, even in the absence of any real forces.
Jan28-13, 11:57 PM   #17
Quote by rcgldr View Post
If you think about it, the reactive force is just the force exerted by the car on to the road, but this does not relate (even remotely) to the diagram .
The diagram shows that there "seems" to be a force acting on the objects which tend to move outward (in the opposite direction of centripetal force). So the force you talked about is the force exerted by the car on the road and not the objects.
Think about this :
You are sitting on the backseat of a car, and this car is turning around a corner at high speed. You would have noticed yourself moving outwards (right ?) until you reach the door of the car which then would provide the appropriate centripetal force to your body.
Notice that this situation is based on the fact that friction could not provide the centripetal force. Notice also that at all times you would be "FEELING" some outward push , (again , which in my opinion is just inertia but not centrifugal force)
Am I right in the above mentioned aspect ?
New Reply
Thread Tools
Similar Threads for: What exactly is centrifugal force
Thread Forum Replies
G-Force and (possibly) Centrifugal force applied to the rotation of a car Introductory Physics Homework 0
Centrifugal Force Introductory Physics Homework 4
centrifugal force General Physics 14
difference between pseudo force and centrifugal force General Physics 15
Centrifugal force Introductory Physics Homework 0
