| New Reply |
Sidebands in AM Transmission |
Share Thread | Thread Tools |
| Jan31-13, 04:51 PM | #1 |
Say you are transmitting AM radio signals. You input an audio signal of 1khz which is used to modulate a signal of 1 mhz. The heterodyning process outputs 4 different frequencies, the audio, carrier, sum, and difference. But where are the sum and difference?
If I look at a graph of the modulated waveform, I can see the carrier and the audio (as amplitude variation in the carrier), but where are the other two? The sidebands as they are also known. I'm not seeing how you add and subtract the frequencies if you are using the audio signal to modify the amplitude of the carrier. When you transmit the signal from your antenna, are you sending power through the two sidebands as well, or only on the main carrier frequency? |
| Jan31-13, 05:42 PM | #2 |
When you measure a modulated waveform there are several ways to picture the changes. If you only look at the time vs level domain it's hard to see the changes. What you need is a way to see the other domains of the signal.
http://www.naic.edu/~phil/hardware/M...r_basis_of.pdf https://www.youtube.com/watch?v=Lp6sT-n55N4 With today's electronics some pretty cool stuff can be made for cheap. http://www.youtube.com/watch?v=ZuRcaxpbYCw |
| Jan31-13, 05:55 PM | #3 |
| Jan31-13, 06:11 PM | #4 |
Sidebands in AM TransmissionYou can't normally see side-band signals with a time-domain display. |
| Jan31-13, 06:34 PM | #5 |
Edit: Whoops, just noticed the link. Reading it now. Ok, that's interesting. According to the link: |
| Jan31-13, 07:24 PM | #6 |
Mentor
See if post #4 in this thread by the_emi_guy helps:
http://www.physicsforums.com/showthread.php?t=606315 . |
| Jan31-13, 09:01 PM | #7 |
Recognitions:
An ideal mixer multiplies two signals. Use trig identities to write
cos(fm)*cos(fc) = cos(fm+fc) + cos(fm-fc)] / 2 A real mixer is non-ideal and allows some of fc to leak through to the output. (Leakage of fm is far away and is filtered out). Real mixers also produce harmonics and high-order mixing products, which again are filtered away. |
| Jan31-13, 09:31 PM | #8 |
Maybe this is a bad question, but are the sidebands actually propagating outwards from the antenna along with the modulated carrier? Or is this just something that happens when you "do the math"?
| Jan31-13, 10:17 PM | #9 |
Mentor
| Jan31-13, 10:27 PM | #10 |
Mentor
The modulating signal (the one that contains the actual information content) already contains a whole continuous spectrum of frequencies. It's a theorem from Fourier analysis that you can represent an arbitrary time-variable signal as a sum* of sinusoids of different frequencies and amplitudes. So that information signal contains a continuum of frequencies, from 0 up to some maximum frequency (that defines the bandwidth). You would see this if you were to look at the frequency spectrum of the signal (which you do by taking its Fourier transform). Anyway, what multiplying this signal by the carrier does is simply to shift the frequency spectrum so that instead of one spectrum being centred on zero, there are now two identical such spectra centred on +carrier frequency and -carrier frequency. To see why this is, you'd need to understand more about Fourier transforms and convolution. *I use the term "sum" loosely, it's actually an integral called an inverse Fourier transform |
| Jan31-13, 10:47 PM | #11 |
You say it doesn't exist in real space? Could you elaborate? I'm unfamiliar with frequency domain as well. If this is too complicated without understanding both frequency domain and fourier analysis just say so. |
| Jan31-13, 11:02 PM | #12 |
Mentor
A sideband is a feature on this plot. The upper sideband is the portion of the spectrum that lies above the carrier frequency, and the lower sideband is the portion of the spectrum that lies below the carrier frequency. |
| Jan31-13, 11:09 PM | #13 |
Mentor
I just read the OP and saw that you were considering a simpler case where the modulating (information-containing) signal is also just a sinusoid at a single frequency. Sorry, I hope I haven't confused things by talking about a more general case with a broadband spectrum.
| Jan31-13, 11:18 PM | #14 |
| Feb1-13, 12:45 PM | #15 |
One way to look at the creation of sideband frequencies is to work the problem in reverse. A function (signal) can be decomposed into purely sinusoidal components. You want to create a AM single frequency modulation time-domain display on your oscilloscope display. To create this display you have RF frequency generators and a summing network. What set of frequencies would you have to set the RF generators to recreate the AM modulation display.
| Feb1-13, 01:27 PM | #16 |
| Feb1-13, 01:39 PM | #17 |
Recognitions:
It might help to note that components of a sine wave undergoing a change in amplitude appear similar to a higher or lower frequency sine wave of fixed gain (steeper or milder ramp rates near the crossover point). The rate of change in the gain determines the bandwidth consumed by the modulated signal. Morse code AM transmistters, which turn signals on and off, are designed to take 5 ms to switch the signal on and off, in order to reduce the bandwidth.
| New Reply |
| Thread Tools | |
Similar Threads for: Sidebands in AM Transmission
| Thread | Forum | Replies | ||
| Transmission Lines | Electrical Engineering | 4 | ||
| ehv dc transmission | Electrical Engineering | 5 | ||
| HIV transmission | Biology | 5 | ||
| Power Transmission | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Transmission | Advanced Physics Homework | 5 | ||
