| New Reply |
con rod length increase |
Share Thread | Thread Tools |
| Jan29-13, 12:58 AM | #1 |
hello, what happen if cod rod length increase by few hundred microns?
| Jan29-13, 02:47 AM | #2 |
the closest pistojn to cylinder head clearance should be 0.050" ( 1250 microns) and having closer distance would mean the piston hits the cylinder head and bends the connecting rod. This is a V8 cast iron engine forged con rod spec and a general guide line so beware...
| Jan29-13, 02:52 AM | #3 |
my supplier asking for 150 micron increase in length tolerance?
| Jan29-13, 03:08 AM | #4 |
Well is an online forum really the place to be asking for advice? We don't know your design, we don't know what is important.
What happens if the conrod tolerance is increased by 0.15mm? The conrod could potentially be upto 0.15mm longer than previously spedified. That's really the only sensible answer we can give. |
| Jan29-13, 05:40 AM | #5 |
Thanks Chris for your concern, It all about engine performance that concern me.
My liitle concern about what it will increase the piston thrust. |
| Jan29-13, 09:48 AM | #6 |
Recognitions:
As the others said, it needs MUCH more information to answer to your question. |
| Feb1-13, 11:55 AM | #7 |
What is the rod length?
What is the piston top to cylinder head clearance? |
| Feb4-13, 04:01 AM | #8 |
clearance-1.5mm |
| Feb5-13, 04:21 AM | #9 |
Unless you are running a true hemispherical combustion chamber, you need to think about detonation in the quench areas. But, more importantly, you need to be asking why your supplier can't hold tolerance any longer.
| New Reply |
| Thread Tools | |
Similar Threads for: con rod length increase
| Thread | Forum | Replies | ||
| how to calculate increase of mass in relation to increase in velocity? | Special & General Relativity | 2 | ||
| How to increase force or length this unit? | Mechanical Engineering | 0 | ||
| Audio Distortion With and Increase in the length (NOOB) | Electrical Engineering | 2 | ||
| calculate resultant increase in length of a 5mm long roof tie CAN SOMEONE HELP ME ! | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Space travel, mass increase, and length shorteneing | Introductory Physics Homework | 3 | ||
