New Reply
Force exerted over a small time and big time frame
Share Thread Thread Tools
Feb6-13, 09:25 AM   #1
Hi
Why is it that if you hit an object fast it requires less force to break it than if you hit the object slow and applied pressure to it?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Feb6-13, 09:37 AM   #2
If you hit it fast, the forces are higher.
Feb6-13, 10:13 AM   #3
So you are saying if I hit a block of wood or glass really fast, it takes the same force to break it than if i use a force press and it slowly applies force to the block of wood or glass?
Feb6-13, 10:20 AM   #4
Mentor
No, he said HIGHER.
However, it may take less impulse (force times time).
Feb6-13, 10:23 AM   #5
Quote by russ_watters View Post
No, he said HIGHER.
But why would it be higher, shouldn't it be just the same force required to break the boards or glass, no matter if it is hit fast or slow?
Feb6-13, 10:29 AM   #6
Mentor
When you apply a force, the object moves - even when holding it rigidly, it bends. The faster you apply the force, the more of the force that is absorbed by the acceleration of the object.
Feb6-13, 02:39 PM   #7
Quote by Howlin View Post
The peak contact force is higher not the force required to break .
New Reply
Thread Tools
Similar Threads for: Force exerted over a small time and big time frame
Thread Forum Replies
Impulse/force in pounds for the time frame General Physics 350
Rest frame through a force field possible (time dilation) ? Special & General Relativity 6
most force/strength used in the same time frame General Physics 69
What average force is exerted on the ball during the contact time? Introductory Physics Homework 1
The normal force exerted on a small sphere Introductory Physics Homework 2
