Glass silvering phenomena and further studies upon reflective layers
The discussion revolves around the optical properties of a transparent rod coated with a reflective layer, specifically addressing whether the internal surface of the rod will reflect light as a result of silvering. Participants explore concepts related to total internal reflection, the nature of reflective coatings, and the implications of complex indices of refraction.
  • One participant questions whether silvering a transparent rod will make the internal layer reflective or if reflection will only occur at the outer surface.
  • Another participant inquires about the concept of front-surface silvering, suggesting it may be relevant to the discussion.
  • It is noted that total internal reflection occurs when the refractive index outside the rod is lower than that inside, referencing Fermat's Principle and Snell's Law.
  • A participant asserts that coating the rod will increase reflectivity, likening it to a mirror, but also mentions that at steep angles of incidence, total internal reflection may negate the effect of the silver layer.
  • There is a clarification that reflection at the interface between the glass rod and the metal does not constitute total internal reflection, which requires specific conditions regarding the refractive indices.
  • Discussion includes the complexity of metal indices of refraction and how they differ from dielectrics, with a mention of Lorentz's theory explaining absorption and reflection phenomena.
Participants express differing views on the effects of silvering on internal reflection, and there is no consensus on how total internal reflection interacts with the reflective layer. The discussion remains unresolved regarding the implications of complex refractive indices.
Participants reference the conditions necessary for total internal reflection and the complexities of reflective coatings, indicating that assumptions about refractive indices and angles of incidence are critical to the discussion.
m0022l
I was working on this college project in optics, and I was thinking of ways to preserve light by multiple reflections. The question is, if I manage to coat a transparent glass (or acrylic) rod with a reflective layer (via silvering), will the internal layer of the rod be reflective as well or just the outside? In more words, when propagating a beam inside the rod; will it reflect as a result of silvering?
Science news on Phys.org
Have you studied front-surface silvering?
Metals have complex indices of refraction and the mechanism for reflection is somewhat different than for dielectrics. Short answer, yes, coating the rod will increase the reflectivity. This is essentially what a mirror is--a piece of glass with silver painted on the back. But at some steep angle of incidence, the silver layer won't really do any good because you already have total internal reflection. I don't know how total internal reflection works for a complex refractive index.
Reflection of visible light at the interface between the glass rod and the metal in NOT total internal reflection. That can only occur when moving from an optically denser medium into a less dense one (i.e., n1 > n2).
Wiki has a nice little blurb on the Complex Index of Refraction.
Lorentz developed the theory. Briefly, all materials have complex indices of refraction at all wavelengths. The real part of the refractive index represents the phase speed, while the imaginary part indicates the amount of absorption loss when the electromagnetic wave propagates through the material (classically called the 'extinction coefficient). The extinction coefficient may be near 0 for materials nearly transparent to a given wavelength.
The theory nicely explains absorption bands in dense materials, dispersion, refraction, reflection, and even 'negative' refractivity (n <1.000) wherein light appears to move faster than c. The shape of the absorption curve as a function of wavelength / frequency is referred to as a Lorentzian curve.
  • · Replies 36 ·
  • · Replies 21 ·
  • · Replies 94 ·
15K
