| New Reply |
What is {ℝ}??? |
Share Thread | Thread Tools |
| Feb6-13, 03:50 PM | #1 |
What is {ℝ}???
Hi,
Someone I know tried to convey me the meaning of {[itex]ℝ[/itex]}, stating it represents a set of real numbers. But using notation, {[itex]ℝ[/itex]}, is implying that the real space is (improperly) contained in a set, and I don't think this makes any logical sense. On the other hand, we can say {[itex]x \in S | \forall S \in ℝ[/itex]}, etc....or simply [itex]x \in ℝ[/itex]. Another way of thinking about this is instead of putting your foot in a sock, you are putting the sock into your foot and it's disturbing. Am I right or wrong? Thanks |
| Feb6-13, 03:57 PM | #2 |
It is perfectly valid to put sets inside of other sets. For example, we may consider the set of all subsets of the complex numbers ##\mathbb{C}##. This is called the power set of ##\mathbb{C}## and is sometimes given the notation ##\mathcal{P}(\mathbb{C})## or ##2^\mathbb{C}##. Any subset of ##\mathbb{C}## is an element of ##\mathcal{P}(\mathbb{C})##. For example, we have ##\mathbb{R} \subset \mathbb{C}## and ##\mathbb{R} \in \mathcal{P}(\mathbb{C})##. We can form subsets of ##\mathcal{P}(\mathbb{C})## in the usual way, by putting elements of ##\mathcal{P}(\mathbb{C})## into a set. Thus ##\{\mathbb{Z}, \mathbb{Q}, \mathbb{R}\} \subset \mathcal{P}(\mathbb{C})##, and a special case is a subset containing only one set, such as your example: ##\{\mathbb{R}\} \subset \mathcal{P}(\mathbb{C})##.
| Feb7-13, 02:54 AM | #3 |
Thanks bjunniii, you have a good point. However, let me rephrase my doubt.
We want to use a notation to represent a set of all real number, say [itex]X[/itex]. It is immediately apparent that [itex]x \in X \subseteq ℝ[/itex] for some real number [itex]x[/itex]. In this case, we are not not considering any stronger set, for instance, [itex]P(ℂ)[/itex] as you mentioned. Now having limited ourselves to real space, it is rather redundant to say the set is represented as {[itex]ℝ[/itex]} because since [itex]ℝ[/itex] is not a proper subspace in this case. This is the reason why I said "this does not make any logical sense"; I am ridiculed by those curly brackets! Instead, we could simply write [itex]X \in ℝ[/itex] that give a much more direct and sensible idea of what space we are talking about. Do you agree? |
| Feb7-13, 02:57 AM | #4 |
What is {ℝ}???
The set [itex]\{\mathbb{R}\}[/itex] is a set which contains only one element. Its element is [itex]\mathbb{R}[/itex]. There is no reason why such a construction would not be allowed.
It is true, however, that sets like [itex]\{\mathbb{R}\}[/itex] don't play a big role in mathematics. |
| Feb7-13, 05:32 AM | #5 |
So it does logically exist (in this case A = B = ℝ). |
| Feb7-13, 09:26 AM | #6 |
@micromass, @pwsnafu, I see what you are saying. Overall, you have convinced me {[itex]ℝ[/itex]} is possible.
But, The notation with curly bracket is directly defining the single element in this set as the real space which is essentially another set. I was simply saying there is no necessity to put real space as a subset of a set in the first place; there are no other disjoint elements. |
| Feb8-13, 07:00 AM | #7 |
But ##\{\mathbb{R}\} \neq \mathbb{R}##. The left hand side is "a set with one element, and that element is ℝ". They are not the same thing. |
| Feb9-13, 10:30 AM | #8 |
Aha, there we go. Thanks alot pwsnafu for the verification! as well as others for your time generous reply.
| New Reply |
| Thread Tools | |
Similar Threads for: What is {ℝ}???
| Thread | Forum | Replies | ||
| Topology on Eculidean n-space(ℝ^n) | Topology and Analysis | 5 | ||
| x^2 = 2 has solution in ℝ | Topology and Analysis | 4 | ||
| Sketching Regions in ℝ^2 | Calculus & Beyond Homework | 12 | ||
| Completeness of ℝ (when ℝ is defined abstractly) | Topology and Analysis | 2 | ||
| Vector Space {∀ x ϵ ℝ+ : x>0} | Calculus & Beyond Homework | 11 | ||
