| New Reply |
Meteorite crash in Russia |
Share Thread | Thread Tools |
| Feb18-13, 11:45 AM | #86 |
Mentor
Meteorite crash in RussiaThere are plenty of small solar system bodies that orbit in the same orbital zone about the Sun as does the Earth. The total mass of all of those bodies doesn't come anywhere close to the mass of the Earth. |
| Feb18-13, 12:28 PM | #87 |
Almost free, relative to development of an effective early warning system that can detect incoming meteors, would be an advertising effort that simply explains that it's necessary to seek cover away from windows in the event of a brilliant flash of light.
I suspect that many of the injuries were caused by people going TO windows after the flash to see what was going on... |
| Feb18-13, 02:37 PM | #88 |
| Feb18-13, 06:23 PM | #89 |
Mentor
If all you meant was that if some event like a close encounter with the moon perturbs its trajectory just before it hits earth (or bouncing off the atmosphere or getting hit by a nuclear bomb), an asteroid could hit the earth a little below escape velocity, then we're all good. The paper I linked mentions the effect of the moon. Heck, the moon has its own mass and escape velocity and will often act to increase the impact velocity on earth! |
| Feb18-13, 06:37 PM | #90 |
Mentor
Now we'll have to quibble over the definitions of "moon" and "asteroid" as it pertains to object size. |
| Feb18-13, 07:13 PM | #91 |
Here is a contrived, but possible situation. An asteroid hits the Moon a glancing blow and is sent from there to a point just past the Earth-Moon L1 Lagrange point with a velocity nearly zero w.r.t. the Earth. At what speed will this asteroid hit the Earth? Neglect air resistance.
| Feb18-13, 07:22 PM | #92 |
Mentor
A couple of examples of such temporary moons: J002E3, which turned out to be the upper stage of the Apollo 12 spacecraft, and 2006 RH120, which is a natural satellite. NASA recently used weak stability boundary transfer concepts to get the GRAIL satellites to the Moon. Instead of going directly to the Moon, the satellites went out almost to the Sun-Earth L1 point and then fell back toward the Moon on a ballistic capture trajectory. The 3 to 3.5 day journey to the Moon used by the Apollo program became a two month long slow drift, but saved a whole lot of fuel. (The so-called Interplanetary Highway System would be more aptly named as The Interplanetary Conestoga Wagon Trail. It's never fast to use those weak stability boundary transfers.) |
| Feb18-13, 07:24 PM | #93 |
The reason the other governments aren't so into it is because most of them are poor. They want to develop their economies and that's what their constituents also want. The difference here is the narrative and in developing countries they don't have the same levels of fear mongering about this, so that's not high on their list of priorities. Interestingly enough one of the effects of this is to render all of our CO2 control efforts, ineffectual as they often are, a complete waste of time. Even if our carbon emissions went to zero it wouldn't matter because the growth of the third world. |
| Feb18-13, 08:53 PM | #94 |
Which eventually prompted your reply.... It has to be an asteroid that has moved into the Earth region recently, since the Earth tends to clean out debris too close to its own orbit. While that happens continuously (or else we wouldn't have as many near earth asteroids as we do and also means "clearing the neighbourhood" is an unending task, as DH pointed out), the probability of altering it to meet the criteria for a low velocity collision makes "very unlikely" an understatement. Actually, I think I did say, or at least implied, that there was a time in the past (early in the solar system) that low velocity impacts were common (even if a very low percentage). They aren't common now. |
| Feb18-13, 10:02 PM | #95 |
With an orbital period of 240,000,000 years for the sun to go around the galactic center, we should look for clues around that time period in the past. It looks like we transitioned from the Paleozoic to the Mesozoic eras around 250,000,000 years ago. Did anything special happen back then? I'm not much of a historian. Lot's-o-space rocks maybe? This might be fun. I've never seen a big meteorite before. hmmm....
| Feb19-13, 08:53 AM | #96 |
Mentor
Or put another way, it sounds like you think an unperturbed trajectory (again, of at least the last 10 million km) exists that can cause a below escape velocity impact and that most or all NEOs that hit us have such such a trajectory by definition of being NEOs. It doesn't make sense to me that you used the Earth sweeping out its NEOs as an example unless you think a significant fraction of them (all of them?) Impacted at below escape velocity. Could you please try to answer more succinctly because all of the qualifiers you are putting on this don't add clarity and seem to contradict your examples. |
| Feb19-13, 10:05 AM | #97 |
Mentor
Regarding the paper you linked, the authors didn't write clearly, which in turn led you to misread/misinterpret what they wrote. This is, I think, the bit from that article that you are interpreting incorrectly: Most asteroids snagged by Earth's gravity don't zoom around our planet in neat circles, according to the simulation. Instead, they follow complicated, twisting paths, tugged this way and that by the gravitational pulls of Earth, the moon and the sun.That "snagged by Earth's gravity" was not alluding to the asteroids that impact the Earth. It was alluding to the very, very few asteroids that, at least temporarily, orbit the Earth. Most (almost all) asteroids that impact the Earth aren't "snagged by Earth's gravity" (i.e., orbiting). They came in to the vicinity of the Earth on a hyperbolic trajectory and they would have immediately have left on a hyperbolic trajectory had the Earth not have been in the way. What that part of the article was alluding to is that it is unlikely to capture an asteroid and have it end up in a circular orbit. Very, very unlikely. For example, the "captured asteroid" explanation for the moons of Mars has come under increased scrutiny because this explanation doesn't make sense from a dynamical point of view. |
| Feb19-13, 02:07 PM | #98 |
If the Russian meteorite released 20 Hiroshimas of energy, then how come only two people were injured? I'm guessing they're measuring energy from the time it entered the Earth's atmosphere until it hit the ground, whereas the Hiroshima Bomb released all of its energy right at one time, the meteorite released its energy over a long period of time. Still, that doesn't sound like a good explanation to me.
| Feb19-13, 02:26 PM | #99 |
Admin
| Feb19-13, 02:42 PM | #100 |
| Feb19-13, 08:27 PM | #101 |
hmmm.... from my calculations, this meteor arrived with a speed of 17.8 km/sec Earthsky.org lists these numbers for various showers: Bah! Lame! Slower than a Draconid!
| Feb20-13, 06:26 AM | #102 |
You can't have an unperturbed trajectory. Both the asteroid and the Earth are orbiting the Sun and the Earth is perturbing the asteroid's orbit (and, likewise, the asteroid is just slightly perturbing the Earth's orbit). To glance at the orbits of near Earth asteroids, you'd say a lot of them look pretty similar, but having a similar size isn't enough. They have to match other parameters as well. And they have to collide before their orbit is changed again. |
| New Reply |
| Tags |
| asteroid da14, chelyabinsk, meteor, russia |
| Thread Tools | |
Similar Threads for: Meteorite crash in Russia
| Thread | Forum | Replies | ||
| Oregon meteorite | General Discussion | 5 | ||
| Crash Crash Question | General Physics | 5 | ||
| Meteorite falling on a Car... | Introductory Physics Homework | 6 | ||
| Meteorite Collision Modelling | General Astronomy | 2 | ||
| Midwesterners take a meteorite shower | General Astronomy | 4 | ||
