New Reply
A small question regarding force/stress/area
Share Thread Thread Tools
Feb19-13, 05:58 AM   #1
Hello friends, I have a small query regarding a force being applied to a surface...
I have a force of 0.1MN which is being applied in the -y direction onto a surface.
Now I know that if said surface was flat, I would divide the force by the area to give me the stress.
However the force is being applied to a curved surface (a u shape).
Is the process the same?
Do I just simply calculate the area of that surface or is there another procedure involved?
Many thanks,
Tina
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb19-13, 06:36 AM   #2
This needs a sketch and a description of how the force is applied. Does 'flat' mean horizontal, vertical or sloping? Does 'u-shape' mean 2-dimensional or 3-dimensional?
Feb19-13, 06:59 AM   #3
My apologies. Here is a rather crude sketch of the problem.
The load acting on the hole is supplied by a pin of diameter 0.0195m.
This is all the information that is given to me, so assumptions may have to be made I would imagine...
Feb19-13, 09:13 AM   #4
DTM
The stress on the contact area between pin and u hole is complex. If the pin and hole are of approximately equal size, an approximation can be used you could calculate your compressive stress as F/A with the area being .02x.01
If the pin is much smaller than the hole, I'll see if I can find the equation.
Feb19-13, 04:02 PM   #5
The hole has to be larger than the pin if it is to be fitted cold. Therefore the actual contact is theoretically a line load with no thickness. However, if you know the yield strength of the pin you can work out the lower bound on the contact area from that. However, this is a very common problem and most engineers calculate the stress as load/ projected area (as DTM has suggested). In assessing strength they will be using experimental data using the same nominal assumption of projected area, even though it is known to be false. There are other complications: To get the load into the pin from outside the object illustrated, the pin has to bend a little, throwing most of the stress to the edges of the hole (in a way that is indeterminate) rather than uniformly distributed as is usually assumed.
Feb19-13, 05:08 PM   #6
There are 3 diffrent types of stress you should consider for the plate: tensile, bearing, and shear stress (tear out). DTM describes the bearing stress of the bolt acting on the plate. Tear out should be fine if you follow the standards, but it's good to check anyway.
New Reply
Thread Tools
Similar Threads for: A small question regarding force/stress/area
Thread Forum Replies
Fluid mechanics - pressure, area, force question Classical Physics 1
When calculating the shear stress, what should the area be? Engineering, Comp Sci, & Technology Homework 4
Area of a Small Loop of a Lemniscate Calculus & Beyond Homework 2
Physics - Question - Stress, Area & Factor of Safety? Engineering, Comp Sci, & Technology Homework 3
Force/Suface area question Introductory Physics Homework 3
