New Reply
What is the common way to round up this number?
Share Thread
Feb22-13, 11:17 PM   #1
0.444448
I want 4 digits.
Is it 0.4444
or is it
0.4445 because I say "since the next one becomes 5 because of the 8 then I consider the previous one a 5 as well"?
PhysOrg.com mathematics news on PhysOrg.com
>> Pendulum swings back on 350-year-old mathematical mystery
>> Bayesian statistics theorem holds its own - but use with caution
>> Math technique de-clutters cancer-cell data, revealing tumor evolution, treatment leads
Feb22-13, 11:23 PM   #2
It is less than halfway between 0.4444 and 0.4445 so you should not round up.
Feb22-13, 11:26 PM   #3
Quote by DrewD View Post
So, should it be limited to 0.44445 (from 0.444448) even if one aims for 4 digits?
edit: Also I'm not sure what 'less that halfway' means (in this context).
Feb22-13, 11:28 PM   #4
Recognitions:
Homework Helper Homework Help
The rule is to round to the value that the number is closest to.
0.4444 <---<<< round down value
0.444448 <---<<< the number being considered
0.44445 <---<<< half-way mark (thanks DrewD)
0.4445 <---<<< round up value
0.444448 is closer to 0.4444 than it is to 0.4445 so you round down.
This is why the rule-of-thumb is that you only need to consider the next digit along when rounding.
Feb22-13, 11:56 PM   #5
This is also the reason you don't want to round "along the way" in your calculations. You try to do all of your rounding at the end, otherwise multiple roundings can compound and give you the wrong answer like they did here.
Feb23-13, 12:59 AM   #6
Mentor
Quote by ModusPwnd View Post
Which means either (a) you keep your numbers in your calculator (using memory registers if necessary) throughout the calculation until the end, or (b) you do all the algebra first, symbolically, to get a single formula for your final result, then plug your numbers in and calculate the result all at one go in your calculator.
Feb23-13, 01:49 AM   #7
Ah thanks, I get it now. I should be thinking "it's 0.4444 because the 48 that follows is still lower than 50".
New Reply
Similar discussions for: What is the common way to round up this number?
Thread Forum Replies
Highest Common Factor and Lowest Common Multiple Precalculus Mathematics Homework 2
Cyclical Integration by Parts, going round and round Calculus & Beyond Homework 7
Minimum number of common elements in sets Set Theory, Logic, Probability, Statistics 2
VOTE PF Photo Contest - Going 'Round And 'Round General Discussion 14
Spaceships a'turnin round and round -- in space Astrophysics 5
