New Reply
bandwidth at resoance and peak dB level
Share Thread
Feb24-13, 02:27 PM   #1
Hi,
I'm investigating what happens to bandwidth at resonance of a series RLC circuit when each component is doubled.
i have simulated the circuits and created a bode plot. You can see from the photos that at resonance the gain peaks at -20.82 dB. I would like to know how to calculate this value.
i have an input voltage of 10Vp and the voltage at resonance across the resistor is 6.428V. i understand that the voltage across both resistors is 7.07V because the multimeter is measuring RMS but how do i calculate the db level.
PhysOrg.com engineering news on PhysOrg.com
>> Paris Air Show peek: Wide-body battle and drones (Update)
>> New accurate portable instrument to measure the light pollution levels of a city
>> Use of drones raises questions
Feb25-13, 04:10 AM   #3
Thanks for the reply but that still doesn't tell me how to calculate the -22 dB.
Feb25-13, 09:46 AM   #4
You have a voltage divider with impedances:
Z1 = R1 + j*omega*L + 1/(j*omega*C) = R1 + j*(omega*L - 1/(omega*C) )
Z2 = R2
Your measured voltage, call it Vout, is then given by:
Vout = Z2/(Z1 + Z2) = R2/(R1 + R2 + j*(omega*L - 1/(omega*C) ) )
with magnitude:
|Vout| = R2/sqrt( (R1 + R2)^2 + (omega*L - 1/(omega*C) )^2 )
Find peak value by finding roots of the derivative of |Vout| with respect to omega and substitute into Vout, you probably know the drill.
My solution gives:
Peak value = R2/sqrt( (R1+R2)^2 + (L/sqrt(L*C) - sqrt(L*C)/C)^2 ) = 0.0909 V = -20.8279 dBV
for R1 = 10 ohm, R2 = 1 ohm, L = 70 mH, C = 110 uF.
Feb25-13, 10:12 AM   #5
Thanks,
Once you're broke down the equations its made it easier to see what is going on.
Thanks for the help :)
New Reply
Similar Threads for: bandwidth at resoance and peak dB level
Thread Forum Replies
Plancks law: Relationship between peak wavelength and peak frequency Advanced Physics Homework 11
Resoance states and quark annihilation High Energy, Nuclear, Particle Physics 1
Bandwidth vs frequency bandwidth in a network Computers 4
Boosting pwm peak to peak voltage Electrical Engineering 8
the party's over: peak oil has distracted us from peak helium! General Discussion 11
