New Reply
Electric Field at a Point
Share Thread Thread Tools
Feb24-13, 03:05 PM   #1
1. The problem statement, all variables and given/known data
A charged rod of length L = 1.00 m lies centered on the x axis as shown. The rod has a linear charge density which varies according to λ = ax where a = −90.0 μC/m.
What is the x component of the electric field at a point on the x axis a distance of D = 2.00 m from the end of the rod?
2. Relevant equations
E=kQ/r^2
charge density = Q/A
3. The attempt at a solution
I really do not understand...Where do I get the r from? Since its not uniformly distributed how can there be any field outside?
Would my r = (D-(half of L))?
I'm assuming lambda is just regular charge density at a location of x?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb24-13, 03:44 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Broem!
Quote by Broem View Post
Yes.
(and of course it's a linear charge density, ie coulombs per metre, not per metre3 )
Not following you.
Feb24-13, 04:11 PM   #3
Thanks for the quick response!!
Ok so here's where I am:
I now know that lambda = Q/L so Q = L * (lambda)
So I'm left with
9e9(-9e-6)/(2-.5)^2
This however is not the correct answer...Where can I go from here?
Feb24-13, 04:18 PM   #4
Recognitions:
oh, no, you'll have to integrate
use coulomb's law to find the electric field from a tiny section [x,x+dx] (whose charge will be λdx, and which you can assume is concentrated entirely at x), and integrate from -L/2 to L/2
Feb25-13, 09:26 AM   #5
I got it!!!
Thank you so much for your help!!!
New Reply
Thread Tools
Similar Threads for: Electric Field at a Point
Thread Forum Replies
Point Where Electric Field=0 (3 point charges on x-axis) Introductory Physics Homework 3
Calculating the Electric Field Strength at a certain point with multiple point charge Introductory Physics Homework 1
Mastering physics: The Electric Field at a Point Due to Two Point Charges Advanced Physics Homework 2
Two charges create an electric field--electric field strenght at a point above h.fiel Introductory Physics Homework 4
electric field and electric potential for point charges problem Advanced Physics Homework 2
