Acceleration, bicyclists and ski racing
  • Context: Undergrad
  • Thread starter Thread starter pheadden
    Acceleration Racing
The discussion revolves around the dynamics of acceleration in cycling, particularly comparing two cyclists of different weights coasting down a hill. Participants explore the effects of momentum, wind resistance, and friction on their acceleration, questioning the implications of mass and cross-sectional area in this context.
  • One participant questions why a heavier cyclist (195 lbs) passes a lighter cyclist (120 lbs) while coasting, suggesting it relates to momentum but struggling to quantify it.
  • Another participant argues that ignoring wind resistance and friction is problematic, asserting that these factors significantly affect acceleration.
  • A participant acknowledges the impact of wind resistance but posits that a larger rider would experience more wind resistance, complicating the relationship between weight and acceleration.
  • One participant presents a mathematical analysis indicating that a larger, heavier rider would accelerate faster due to the ratio of gravitational force to wind resistance, challenging the initial assumption.
  • Another participant emphasizes that in the absence of air resistance and friction, both riders would continue to accelerate downhill indefinitely.
  • A participant expresses confusion about the dynamics, referencing Newton's 2nd law and the behavior of objects in a vacuum, while noting their experience contradicts the mathematical analysis presented.
  • Clarification is provided that the larger rider is indeed the heavier one, with a specific scaling factor discussed to illustrate the differences in mass and acceleration.
Participants do not reach a consensus, as there are competing views regarding the effects of weight, wind resistance, and the implications of Newton's laws on the acceleration of the cyclists.
The discussion highlights limitations in assumptions about wind resistance and friction, as well as the dependence on specific conditions such as the shape and scaling of the cyclists.
pheadden
So I'm a 195# cyclist, coasting down a hill. I pass the 120 # cyclist who is also coasting. I'm not sure why. Ignoring wind resistance and friction - which I believe aren't significant here - shouldn't we accelerate at the same rate? I believe it has to do with the fact that I'm carrying more momentum, but I can't quantify it. It's the same deal as downhill skiers, they tend to be larger because with more weight, they carry more momentum into the flats. Any thoughts?
Your problem is with "ignoring wind resistance and friction". They certainly are important! If there were no wind resistance and friction, you would both go at the same rate. You go faster because there is wind resistance and friction.
Thanks, Wind resistance and friction definitely have an impact, but with me being the larger rider with a presumably larger cross section, I would think I have more wind resistance than the smaller rider. The friction of my bike's bearings and tires on the road, has got to be negligible. I think it has to do with momentum, P=MV, but I can't reconcile F=MA.
Yes, being larger you presumably have a larger cross-section. But assume that you have two riders of exactly the same shape, but Rider B is scaled up relative to rider A by a factor X. Rider B's mass will be X^3 times larger than Rider A, so the force pulling him downhill will be X^3 times larger. But his cross-sectional area will be only X^2 times larger, so the wind resistance holding him back will only increase by X^2. So the net acceleration of Rider A will be:
[tex]a_A = \frac{F_G - F_W}{M}[/tex]
while the net acceleration of Rider B will be:
[tex]a_B = \frac{X^3 F_G - X^2 F_W}{X^3M} = \frac{F_G - \frac{F_W}{X}}{M}[/tex]
So Rider B will accelerate faster.
Keep in mind that if there were no air resistance and friction, you would basically keep accelerating downhill and never hit a top speed.
Thanks, but my experience is that the heavier rider, Rider A, passes rider B while coasting down hill, even if they start at the same velocity, v0. PHyzguy's analysis indicates the opposite should occur. I believe Newton's 2nd law of motion indicates that in a vacuum (no friction/resistance), a bowling ball and a feather will accelerate at the same rate. Thus if they are both dropped from a building, they will hit the ground at the same time. So I'm still confused.
No, you've missed it. Rider B is the bigger, heavier rider. He is X times larger in scale and X^3 times heavier than rider A. X is a number greater than 1. For the case you gave with Rider A at 120 pounds, and Rider B at 195 pounds, X would be about 1.17.
  • · Replies 41 ·
  • · Replies 36 ·
10K
  • · Replies 69 ·
18K
