Dot product with 3 dimensions, confused on concept, easy question i think
The discussion revolves around the concept of the dot product in three dimensions, specifically applying it to a vector function r(t) expressed in terms of its components. Participants are exploring the implications of taking the dot product of a vector with itself and the resulting interpretations.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are questioning the nature of the dot product when applied to the same vector, considering whether it results in the magnitude squared. There are discussions about the role of unit vectors and the application of the chain rule in related parts of the problem.
The discussion is active, with participants providing insights and corrections. Some have offered clarifications regarding the mathematical properties of the dot product, while others are still grappling with the implications of their findings and the relevance of the chain rule.
There are indications of confusion regarding the setup of the problem, particularly with the notation and the application of mathematical rules. Participants are also reflecting on the nature of the functions involved and their relationships.
mr_coffee
Hello everyone! I'm confused on what I'm suppose to do here, I think i might got it though but i need to make sure...
Here is the problem and my work:
http://show.imagehosting.us/show/764032/0/nouser_764/T0_-1_764032.jpg
he let r(t) = f(t) i + g(t) j + h(t) k. So if i multiply this by itself, won't that make the vectors go away? because isn't (i)(i) = (j)(j) = (k)(k) = 1?
Thanks!
In the very first line, g(t) needs a j unit vector.
For part (b), remember to apply the chain rule.
Well if it's the same vector, then essentially it's the dot product of two vectors that are parellel, that is, the angle between them is 0. So it will be the magnitude of the vector squared. That's how I see it anyway...
Thanks for the replies, I see big man, that makes sense but he isn't asking what |r(t) dot r(t)| he is asking r(t) dot r(t). Also Whozum, Thanks for picking that up in a, but is that right, the dot product of the same vector, will the unit vectors just be all one and ur just left with the functions of f(t) + g(t) + h(t)? Somthing seems odd there...also why would the chain rule apply to part b? Don't you apply the chain rule when you have somthing like, f(g(x))? or (x-3x^3)^(2)?
For the first part,
[tex]\vec{r}(t) \cdot \vec{r}(t) = |\vec{r}(t)|^{2} = c^2[/tex]
for the 2nd part
[tex]\frac{d}{dt} \vec{r}(t) \cdot \vec{r}(t) = \vec{r}'(t) \cdot \vec{r}(t) + \vec{r}(t) \cdot \vec{r}'(t) = 2 \vec{r}'(t) \cdot \vec{r}(t) = 0[/tex]
[tex]\vec{r}'(t) \cdot \vec{r}(t) = 0[/tex]
which basically means both vectors are orthogonal.
Thanks cyclovenom! right when u posted that I Just found the exact same solution in the book :)
  • · Replies 33 ·
