Tell Me About Kinetic Energy, Please
The discussion revolves around the concept of kinetic energy, exploring its definition, implications, and the relationship between force and energy in the context of objects moving at constant velocity. Participants engage in a technical examination of the equations governing kinetic energy and work, including the implications of constant force and velocity.
  • One participant asserts that kinetic energy is defined as E = mV²/2 and argues that if speed is constant, then the resulting force is zero, leading to the conclusion that energy should also be zero (E = 0).
  • Another participant counters that the work done is related to the change in energy, emphasizing that while kinetic energy may not change at constant velocity, it does not imply that kinetic energy itself is zero.
  • There is a discussion about the notation used in equations, with suggestions to use different symbols for clarity, and a debate on the interchangeability of E and dE in the context of energy changes.
  • Some participants reference the Work-Energy theorem, stating that the work done on a system is equal to the change in energy, and question the assumption that energy can be considered zero.
  • A later reply introduces the idea that the kinetic energy paradox also applies to photons, arguing that since photons travel at constant speed, the force is zero, leading to the conclusion that their energy is also zero.
Participants do not reach a consensus, with multiple competing views on the relationship between force, work, and kinetic energy. Disagreements persist regarding the implications of constant velocity on energy and the validity of certain mathematical interpretations.
Participants express various assumptions about the definitions of energy and force, and there are unresolved mathematical steps in the arguments presented. The discussion reflects a range of interpretations of kinetic energy and its application in different contexts.
dock
Tell Me About Kinetic Energy, Please!
according to the traditional physics the kinetic energy is:
E=mVV/2;
let that speed be constant and nonzero => E<>0;
according to Newton the 1st whenevr the speed V=const the resulting force acting upon that object is zero;
the energy by definition is:
E=FxX;
since F=0 => E=0
HOW ABOUT THAT?
Erm... no?
Work done = change in energy is the integral of force with respect to distance.
All this shows is that there is no change in kinetic energy for an object moving at constant velocity.
Which is obvious, really.
And use * instead of x for the multiplication operator. It's less confusing that way.
Originally posted by FZ+
Erm... no?
i'm not talking about dE but E.
OK so dE=FdX then integrated we have (E=FX and F=const)
d(E=FX) <=> dE=FdX cause F=0=const.
so it's not only dE=0 but E=0 also!
when F=const then dE=FdX
when E=const then FdX=-XdF
when X=const then dE=XdF
when none then
dE=FdX+XdF
supportive members, please, be louder!
Let me repeat:
YOU HAVE SHOWN THE CHANGE IN ENERGY.
YOU HAVE SHOWN THERE IS NO CHANGE IN ENERGY.
F * x = Work Done = change in energy
Integral of F wrt x gives F*x + C
The constant of integration C is the initial kinetic energy of the system.
UNDERSTOOD?
Let me repeat:
UNDERSTOOD?
F * x = Work done?
ain't Work done = dE?
how come only one derivate in that equation.that violates the mightiest of the laws:"Every change is simultaneous with at least one other".
& int Fdx = F(x(2)-x(1))
but it's also
& int dE = E(2)-E(1)
and then
E(2)-F(2)x(2)=E(1)-F(1)x(1)=const=0 threrefore
E=Fx
cause
F(1)=F(2)=F
you cannot put starting condition on the staring conditions.it leads no where that's whay that const=0.
Its just different notations in different equations, dock. Apparently wherever you got that from uses dE and E interchangeably. And its not unreasonable to do so since often times a change in E results in a conversion from one form of E to another (such as kinetic being converted to potential).
dock, from the Work-Energy theorom, the change in energy in a system is equal to the work.
So F*x (the work) is equal to dE in the system.
It is right that when F=0, E=const, but why are you taking this const to be 0 ?
this kinetic energy paradox aplies to the photon as well.
the photon has constant speed c => the force is zero => the energy of the photon is zero cause E=FxX=0xX=0.
  • · Replies 41 ·
  • · Replies 16 ·
  • · Replies 54 ·
  • · Replies 138 ·
9K
