Acid base titration problem. Need Help
The forum discussion focuses on calculating the moles of H3O+ required to adjust the pH of a solution from 7.17 to 5.85. The correct calculation yields 1.34E-6 moles of H3O+. The relationship between pH and molar concentration is emphasized, with pH 7.17 corresponding to a concentration of 6.76 x 10-8 M. The method involves determining the molar concentration for the target pH and calculating the difference to find the required moles of H3O+.
  • Understanding of pH and its mathematical definition
  • Knowledge of molar concentration calculations
  • Familiarity with the relationship between pH and H3O+ concentration
  • Basic skills in chemical stoichiometry
  • Learn about pH calculations and their applications in chemistry
  • Study the concept of molarity and its importance in solution chemistry
  • Explore the relationship between pH and acidity in various solutions
  • Investigate titration techniques and their relevance in acid-base chemistry
Chemistry students, educators, and professionals involved in laboratory work or research related to acid-base reactions and solution chemistry.
ddluu
How many moles of H3O+ must be added to one liter of a solution to adjust the pH from 7.17 to 5.85?
Correct answer 1.34E-6 (1.34 * 10-6)
The correct answer is given, however I would like to know how to do this problem.
See definition of pH - http://www.chembuddy.com/?left=pH-calculation&right=pH-definition
The pH is related to the molar concentration.
pH = 7.17 yields a molar concentration of 10-7.17 = 6.76 x 10-8 M, or moles/liter
Now try to find the number of moles in one liter for pH = 5.85.
Take the difference which gives the number of moles of H+ or H3O+ one needs to add to one liter.
  • · Replies 16 ·
