Finding the Centre of Mass of a Cubical Container
The discussion revolves around finding the center of mass of a cubical container made from a metal plate of uniform density and negligible thickness, with an edge length of 40 cm. Participants are exploring the coordinates of the center of mass in three dimensions.
  • Exploratory, Assumption checking
  • Participants are considering symmetry as a method to determine the x and y coordinates of the center of mass. There is uncertainty regarding the y coordinate, with some suggesting it might be zero. Questions arise about how to demonstrate their reasoning and calculations.
The discussion is ongoing, with participants sharing their thoughts on symmetry and its implications for finding the center of mass. Some guidance has been offered regarding the use of symmetry, but there is still exploration of how to formally present their work.
Participants note that the box has no top, which may influence the calculation of the center of mass in the y direction. There is also a focus on how to show their work in the context of the problem.
suspenc3
A cubical container has been constructed from metal plate of uniform density and negligible thickness. The box has an edge length of 40 cm.
Find the x, y, & z coordinates of the centre of mass of the box.
Im guessing that the x and y coordinates are found by the symmetry..But how do i find the y coordinate?
Any help would be appreciated
Now that I think about it, Wouldnt the y coordinate 0?
If this is right, is their any method to show my work, or is it all just found by symmetry?
I'm guessing you mean how do you find the z coordinate. Since a box has uniform length in every dimension it is easy to find the COM in every component through symmetry.
what I meant was : "remember that the box has no top
I can find the centre of mass in the x & z directions through symmetry
How do i find the y component? then i thought about it and realized that it would be "0"...therefore the centre of mass is (20, 0, 20)?
How do I show work for this?
  • · Replies 17 ·
15K
14K
  • · Replies 25 ·
