Packing Case Question: Friction
  • Thread starter Thread starter courtrigrad
    Friction
The discussion revolves around a physics problem involving a packing case on a truck, focusing on the forces of friction as the truck accelerates in different directions. The subject area includes dynamics and frictional forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between acceleration and frictional force, questioning when to apply static versus kinetic friction. There are discussions on using Newton's second law and the maximum static friction force to determine the conditions under which the case might slide.
The discussion is active, with participants providing insights on how to approach the problem. Some guidance has been offered regarding the application of frictional force equations and the conditions for static versus kinetic friction. There is an ongoing exploration of the implications of the truck's acceleration in both eastward and westward directions.
Participants are considering the coefficients of static and kinetic friction, as well as the mass of the packing case. There is a focus on understanding the transition between static and kinetic friction based on the forces involved.
courtrigrad
A 30.0 kg packing case is initially at rest on the floor of a truck. The coefficient of static friction between the case and the floor is 0.30, and the coefficient of kinetic friction is 0.20. The truck is traveling due east at a constant speed. Find the magnitude and direction of the friction force acting on the case (a) when the truck accelerates at 2.20 m/s^2 eastward; (b) when it accelerates at 3.50 m/s^2 westward.
Ok so initially, we have the force of gravity [tex]w = (30 kg)(9.8 \frac{m}{s^{2}})[/tex], the static friction force, and the normal force (equal to the weight but opposite in direction). So for parts (a) and (b) since everything is moving, we have to find the magnitude and direction of the kinetic frictional force. So [tex]f_{k} = \mu_{k}\times N[/tex]. This is where I become stuck. How do you relate the acceleration to finding the frictional force?
Any help is appreciated.
Thanks
You only use kinetic friction when the case is moving over the surface it had been resting on. The truck (and case) may be moving, but that doesn't mean that the case is sliding over the floor. That only happens when the acceleration is so great that the accelerating force is greater then the force of static friction. In that case it becomes the force of kinetic friction that takes over.
So would I use F = ma to find the magnitude of the accelerating force, and then find the friction?
Thanks
Use Fr=mu*Fn to find the (maximum) friction force.
Then use F = ma on the box and show that F is less tham (max) Fr, hence the box does not slide hence static friction rules, hence state what the friction force is.
Part b) is little bit different (but not much) - can you do that ?
Thanks a lot
For part (B) you would use F = ma or F = (30 kg)(-3.50 m/s^2) = 105 N due west. The friction force must then act eastward. Since [itex]f_{s,max} = 90 N[/itex] the kinetic friction rules in this case. So [itex]f_{k} = 0.20(300 N) = 60 N[/itex].
Is this correct?
Thanks
All correct. Kinetic friction, 60N, acting east.
