Conservation of Linear Momentum?
The discussion revolves around a problem involving the conservation of linear momentum and energy in a system of two particles, A and B, which are released from a compressed spring. The mass of particle A is twice that of particle B, and the total energy stored in the spring is 60J. Participants are exploring how to determine the kinetic energies of both particles after they are released.
  • Participants discuss the conservation of momentum and energy as key principles to apply. There are attempts to express these principles in terms of mass and velocity. Some participants question the availability of numerical values for the masses of the particles, while others express uncertainty about how to proceed with the calculations.
There is active engagement with the problem, with participants offering guidance on how to set up equations based on conservation laws. Some participants are still unsure about the next steps and are seeking further clarification on how to derive the kinetic energies from the established equations.
Participants note the absence of specific weights or numerical values for the particles, which may affect their ability to solve the problem completely. The discussion reflects a mix of symbolic reasoning and the need for concrete values to progress.
suspenc3
Particle A & B are held together with a compressed spring between them. When they are released the spring pushes them apart and they fly off in opposite directions free of the spring. The mass of A is twice that of B, and the energy stored in the spring was 60J. Once the transfer is complete, what are the kinetic energies of particle A & B
I have no clue where to start on this one.
Can Anyone Point Me In The Right Direction?
Thanks.
The title of your post gives it away.
There are two conditions that must be met:
That the momentum of particle A is equal and opposite to the momentum of particle B. (conservation of momentum)
That the combined kinetic energy of particle A & B is equal to 60J (conservation of energy)
Write out this two conditions in terms of mass and velocity and you should be able to solve.
Thanks.
Just wondering you know if the answer is in symbolic form or do you have numbers such as the weight of b?
There are no weights given for the two particles
Im still not too sure what to do.
How do I get the values of Ke
Would I use:
[tex]W=\Delta {E}_m_e_c+\Delta {E}_t_h_e[/tex]
Also I don't have a [tex]\vec{v}[/tex]
?can Anyone Help?
Sorry, been away. Ok, advanced reply doesn't seem to be working so hopefully my latex comes out ok.
We'll go through the two conditions (conservation of momentum/energy) separately then combine them.
Conservation of momentum:
The momentum of the system doesn't change. Assuming the system is stationary to begin with.
[tex]P_(total)=0[/tex]
[tex]m_a*v_a + -m_b*v_b=0[/tex] <- the negative is because they are in opposite directions
[tex]m_a*v_a = m_b*v_b[/tex]
[tex](2m_b)*v_a = m_b*v_b[/tex]
[tex]v_a=\frac{1}{2}v_b[/tex]
Now for conservation of energy. The systems total inital energy is 60J. After the exchange is complete all of that energy is kinetic.
[tex]E_(total)=60[/tex]
[tex]\frac{1}{2}m_a*(v_a)^2 + \frac{1}{2}m_b*(v_b)^2 = 60[/tex]
[tex]\frac{1}{2}(2m_b)*(\frac{1}{2}(v_b))^2 + \frac{1}{2}m_b*(v_b)^2 = 60[/tex]
Now let's simplify that a bit.
[tex]\frac{3}{2}(\frac{1}{2}m_b*(v_b)^2)=60[/tex]
[tex]\frac{3}{2}KE_b=60[/tex] where [tex]KE_b=\frac{1}{2}m_b*(v_b)^2[/tex]
