Mass of air leaving a room with temp raised.
  • Thread starter Thread starter Dantes
    Air Mass
The discussion focuses on calculating the mass of air leaving a room when the temperature is raised from 17.2°C to 25°C, with a room volume of 68 m³ and air pressure maintained at 43.6 kPa. The molar mass of the air is given as 36.3 g/mol. The formula used for the calculation is derived from the ideal gas law, specifically P_0V = nRT, leading to the conclusion that the mass difference can be expressed as m_1 - m_2 = (P_0VM/R) × (1/T_1 - 1/T_2).
  • Understanding of the Ideal Gas Law
  • Knowledge of molar mass and its significance in gas calculations
  • Familiarity with temperature conversion in gas equations
  • Basic algebra for manipulating equations
  • Explore the Ideal Gas Law and its applications in thermodynamics
  • Learn about the effects of temperature on gas volume and pressure
  • Study the concept of molar mass in different gas mixtures
  • Investigate real gas behavior versus ideal gas assumptions
Students in physics or chemistry, engineers working with HVAC systems, and anyone interested in thermodynamic properties of gases will benefit from this discussion.
Dantes
A room of volume 68 m^3 contains air having an average molar mass of 36.3 g/mol. If the temperature of the room is raised from 17.2C to 25C, what mass of air will leave the room? Assume that the air pressure in the room is maintained at 43.6 kPa. Answer in units of kg.
Been messing around with the following to get it into the right form, am I on the right track?
[tex]P_0V = n_1RT = \frac{m_1}{M}RT_1[/tex]
[tex]P_0V = n_2RT_2 = \frac{m_2}{M}RT_2[/tex]
[tex]m_1-m_2 = \frac{P_0VM}{R} \times (\frac{1}{T_1}-\frac{1}{T_2})[/tex]
Yo, that looks good to me.
  • · Replies 33 ·
11K
  • · Replies 26 ·
12K
