Solving Pivoting Rod Angular Acceleration
  • Thread starter Thread starter Juntao
    Rod
The problem involves a pivoting rod with a point mass attached, oriented in a vertical plane under the influence of gravity. The objective is to determine the angular acceleration of the rod immediately after it is released from a specific angle.
  • Mixed
  • Participants discuss the setup of the torque equation and the moment of inertia for both the rod and the point mass. There are attempts to clarify the angle used in the torque calculation and the relationship between the forces and angles involved.
Some participants have provided feedback on the setup of the equations, particularly regarding the correct use of angles in the torque calculations. There is an ongoing exploration of the correct approach to find the angular acceleration, with no explicit consensus reached yet.
Participants are working under the constraints of the problem's parameters, including the masses and lengths provided, and are questioning the assumptions made about angles in the torque calculations.
Juntao
Picture is attached.
A rod with mass M = 1.4 kg and length L = 1.2 m is mounted on a central pivot . A metal ball of mass m = .7 kg is attached to one end of the rod. You may treat the metal ball as a point mass. The system is oriented in the vertical plane and gravity is acting. The rod initially makes an angle theta = 27 degrees with respect to the horizontal. The rod is released from rest. What is the angular acceleration of the rod immediately after it is released?
Ok, first I converted 27 degrees to .471 radians.
Now, I know that Net torque =I*alpha
or net torque = [I(rod)+I(point mass)]*alpha
so I got it set up like this
r-r*m2*g*sin .471=[I(rod)+I(point mass)]*alpha
where r is 1.2m/2=.6m
m2=mass of ball=.7kg
m1=1.4kg
I(rod)=1/12*mL^2=(1/12)*(1.4kg)*(1.2m)^2
I(ball)=mr^2=.7kg*(.6m)^2
So yea, does that look like I set it up right? I'm not to sure if I set up my net torque right, but I think I got the other half of the equation correct.
Looks good except for the left hand side of the above, which is the torque. I think you're mixing up the angles.
Ok. I re-tried it with 207 degrees, or 3.61 radians, but that new angle still doesn't give me the right answer. I get an alpha of 5.85 /sec^2.
Not sure what you are doing. The torque is r*F*sinα, where α is the angle between the r and F vectors. But in this case: torque = r*mg*sinα = r*mg*cosθ, by the definition of θ in your diagram. Make sense?
Yea, now it does. Should have said that earlier, but I'm greatfully grateful for your help. I've spent at least an hour on this, but now I'm done. :)
  • · Replies 62 ·
14K
  • · Replies 18 ·
