Thread Closed
Open pipe problem
Share Thread Thread Tools
Nov17-05, 07:49 PM   #1
Open pipe problem
Hello. I'm having some trouble with this problem:
A tuning fork is set into vibration above a vertical open tube filled w/ water. Water level is dropping slowly. As it does so, the air in the tube above the water level is heard to resonate w/ the tuning fork when the distance from the tube opening to the water level is 0.125 m and again at 0.395m. What is the frequency of the tuning fork?
So I subtracted the two distances and got
(n+2)L - nL = .395 - .125 = .270 m
Are 0.125m and 0.395 successive though ?
Now I'm stuck.
Any help would be appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov18-05, 07:05 AM   #2
Admin
From the statement, it would appear that the resonances are successive.
What is the relationship between the speed of sound, wavelength and frequency. If one knows the wavelength, one can find the frequency.
Nov18-05, 07:38 AM   #3
Recognitions:
Homework Helper Homework Help
Since there is a node at the surface of the water the difference between the two lenghts is equal to [itex]\lambda/2[/itex]. I assume one would then use the speed of sound in air, 343 m/s, to calculate the frequency.
Thread Closed
Thread Tools
Similar Threads for: Open pipe problem
Thread Forum Replies
Entrance loss from open channel to pipe Mechanical Engineering 1
[SOLVED] Open ended pipe Harmonics Mastering Physics Question Introductory Physics Homework 9
Reflection of sound from open pipe General Physics 12
Why is a half-filled test tube considered an open pipe? Introductory Physics Homework 0
Loss due to open channel to pipe flow transition General Engineering 3
