How Do You Calculate the Total Moment of Inertia for a Complex Wheel Assembly?
The discussion focuses on calculating the total moment of inertia for a complex wheel assembly consisting of a central hub, spokes, and an outer rim. The hub has a radius of 2m and a mass of 4kg, the rim has a radius of 6m and a mass of 1kg, and each of the four spokes is 4m long with a mass of 2kg. The calculation involves treating the hub as an empty sphere and determining the moment of inertia about an axis through the center perpendicular to the plane of the wheel. Key resources for further understanding include HyperPhysics links for moment of inertia calculations.
  • Understanding of moment of inertia concepts
  • Familiarity with composite structures in physics
  • Knowledge of rotational dynamics
  • Ability to apply the parallel axis theorem
  • Calculate the moment of inertia for the hub using the formula for an empty sphere
  • Determine the moment of inertia for each spoke using the appropriate formula
  • Calculate the moment of inertia for the rim as a thin ring
  • Combine the individual moments of inertia to find the total moment of inertia for the assembly
Physics students, mechanical engineers, and anyone involved in rotational dynamics or structural analysis will benefit from this discussion.
physixnot4me
Hi, I'm stuck on what I need to calculate the moment of inertia... in this type of question:
the wheel shown on a diagram has a central hub of radius 2m and a mass of 4kg, outside rim of radius 6m and a mass 1kg. each of the four spokes is 4m long and has a mass of 2 kg. find the moment of inertia about an axis through the centre perpedicular to the plane of the wheel. treat the hub as an empty sphere.
SO FAR, I've found the moment of inertial of the hub each spoke...
what is my next step?
Diagram is attached.
Thanks =)
  • · Replies 23 ·
10K
