Chem: if u can do this u = genius
  • Thread starter Thread starter gotzmlk
    Chem Genius
The discussion revolves around a chemistry lab report involving the determination of chemical formulas and reactions, specifically focusing on calcium carbonate and copper hydroxide. Participants are examining the ratios of chemicals in test tubes and the resulting compounds formed during reactions.
  • The original poster attempts to gather help on various questions related to chemical formulas and reactions, including identifying products and determining the correct formulas based on experimental results.
  • Some participants question the appropriateness of the request for assistance, suggesting that the original poster should engage more with the material before seeking help.
  • Others suggest reconsidering the specificity of the questions posed, particularly regarding the identification of compounds and the context of the reactions.
The discussion is ongoing, with participants providing varying levels of guidance and feedback. Some have pointed out the need for more information to properly address the questions, while others emphasize the importance of the original poster attempting the work independently before seeking help.
Participants note that the original poster's questions lack sufficient detail, particularly regarding the specific mixtures used in the reactions and the definitions of terms like "salt." There is also a mention of homework etiquette and expectations within the forum.
gotzmlk
Hi, I am having a huge problem with chem. i do not know what the heck is going on so can i have some help.
Drops of each chemical into test tubes
ratios Ca:CO
test tube1: 0:24
test tube2: 1:5
test tube3: 1:2
test tube4: 1:1
test tube5: 2:1
test tube6: 5:1
test tube7: 24:0
Determining Chemical Formulas I
11. Based on valence, what do you think is the correct chemical formula for calcium carbonate?
CaCO3
12. Do your experimental results for the chemical formula for calcium carbonate agree with your chemical formula in question #11?
13. What is the name of the new solid formed in the reaction?
Salt
14. What is the name of the new liquid formed in the reaction?
15. Write the name of each of the compounds below the chemical equation, which shows what reaction, took place:
CaCl2 + Na2CO3 à 2 NaCl
_____________ _________________ __________________
16. If the correct formula for calcium carbonate had been Ca2CO3, which test tube would have contained the greatest amount of precipitate?
17. If the correct formula for calcium carbonate had been Ca(CO3)5, which test tube would have contained the greats amount of precipitate?
18. If the correct formula for calcium carbonate had been Ca(CO3)2, which test tube would have contained the greats amount of precipitate?
19. How could you experimentally determine the correct chemical formula for the new liquid formed?
20. How were the rations of calcium and carbonate determined?
ratios: Cu:OH
test tube1: O:24
test tube2: 1:5
test tube3: 1:2
test tube4: 1:1
test tube5: 2:1
test tube6: 5:1
test tube 7: 24:0
Determining Chemical Formulas II
1. List the elements and the number of atoms of each element in one molecule of copper sulfate?
2. How many different elements are in one molecule of copper sulfate?
3. How many total atoms are in one molecule of copper sulfate
4. What is the symbol and valence for copper II?
5. What is the formula and valence for sulfate?
6. List the elements and the number of atoms of each element in one molecule of sodium hydroxide?
7. How many different elements are in one molecule of sodium hydroxide?
8. How many total atoms are in once molecule of sodium hydroxide?
9. What is the symbol and valence for sodium?
10. What is the formula and valence for hydroxide?
11. Based in valence, what do you think is the correct chemical formula for copper hydroxide?
12. Do your experimental results for the chemical formula for copper hydroxide agree with your chemical formula in question #11?
CuCO4 + 2 NaOH à Na2SO4
16. If the correct formulae for calcium carbonate had been CuOH, which test tube would have contained the greats amount of precipitate?
17. If the correct formulae for calcium carbonate had been Cu2OH, which test tube would have contained the greats amount of precipitate?
18. If the correct formulae for calcium carbonate had been Cu(OH)5, which test tube would have contained the greats amount of precipitate?
19. How could you experimentally determine the chemical formula for the new liquid formed?
Do you honestly want someone to fill out your lab report for you?
This is a homework help forum,
not a "Do my homework for me" forum
here here enigma!
Oh I can do these problems in my sleep. I'm not going to though. It's not fair to the students who didn't procrastinate and not pay attention in class.
Seriously gotzmlk
You may have figured that we aren't going to help you here. I suggest reading your textbook, class notes, study guides and the like.
As Chemicalsuperfreak said, he can do it in his sleep implying that they aren't that hard!
I suggest trying to do at least some of the work and then come back to the forum with REAL problems.
I'd love to help you (refresh my own memory) but you're missing lots of information.
11. CaCO3
12. not enough information
13. Putting "salt" will for sure get you a 0. The term salt is so generic that it's like saying the result is "organic" or "inorganic". The new solid formed is called "calcium carbonate".
14. not enough information (what did you mix together in the first place?)
15. calcium chloride + sodium carbonate = sodium chloride + calcium carbonate
16. test tube 5
17. test tube 2
18. test tube 3
19. there is no liquid formed. to verify this, you could do something like a gas chromatograph or run it through a spectrometer.
20. do you mean ratios?
1. this question is not specific enough. there are 2 different ions for copper.
2. Cu, S, O = 3
3. since the copper ion is not specified, there is more than 1 answer.
4. i couldn't even find the answer on google
5. dunno
6. sodium, oxygen, hydrogen; one of each
7. 3
8. 3
9. dunno
10. dunno
11. copper 2 is more common so i'll say Cu(OH)2
12. sure they do
13. what are you mixing?
14. again, what are you mixing?
15. (just a guess) copper percarbonate + sodium hydroxide = sodium sulfate (conservation of mass?)
That's all for now. superfreak, what are the answers to those valence onces? I never did get the hang of naming orbitals.
as previously mentioned, please don't expect anyone in this world to do your homework for you, tedious, boring, and insulting to your genius as it may be. if you have a puzzleing problem that involves real thinking, then I am sure one person who likes to be flattered as a genius would be glad to help.
still, its ok, u spent as much time copying and pasting ur homework as we did replying. just watch out next time for what you're asking.
24K
  • · Replies 19 ·
11K
16K
22K
