What is the initial speed of the bullet that hits the pendulum?
  • Thread starter Thread starter joex444
    Bullet Pendulum
The initial speed of a bullet that embeds itself in a pendulum can be calculated using conservation of momentum and energy principles. A 10g bullet strikes a 2kg pendulum, causing it to rise 12cm, which converts to 2.36J of gravitational potential energy. The bullet's initial speed is determined to be 308m/s, as confirmed by applying momentum conservation during the collision and energy conservation for the pendulum's subsequent motion.
  • Understanding of conservation of momentum
  • Familiarity with gravitational potential energy (GPE) calculations
  • Knowledge of kinetic energy (KE) equations
  • Basic principles of collision mechanics
  • Study conservation of momentum in inelastic collisions
  • Explore detailed calculations of gravitational potential energy
  • Learn about kinetic energy transformations in collision scenarios
  • Investigate real-world applications of ballistic pendulum experiments
Physics students, educators, and anyone interested in understanding the dynamics of collisions and energy transformations in mechanical systems.
joex444
A bullet, 10g, hits a pendulum, 2kg. The center of mass of the pendulum rises a vertical distance of 12cm. Assuming the bullet embeds itself in the pendulum, calculate the bullet's initial speed.
What I did was assume that at 12cm vertical distance the pendulum and bullet are momentarily at 0m/s velocity, and all their energy is gravitational potential, so mgh = 2*9.8*0.12 = 2.36J. The bullet's inital speed could be found by assuming the pendulum was at rest before being shot, and its GPE was 0. So, 2.36J came from the bullet, and 1/2mv^2 shows that v^2=472m^2/s^2. Taking the square root, v=21.7m/s.
Now, my professor says the answer is 308m/s. 21.7m/s is quite slow for a bullet...
the speed you have of 21.7m/s is the speed of the pendulum/bullet system. Energy is conserved.
you still have one more step to find the initial speed of the bullet, where energy is not conserved.
I think I got it. Momentum during the collision is conserved, so Velocity of the block+bullet = m(bullet)*v(bullet)/(m(bullet)+M(block)). Then I use that V in the KE and GPE conservation equation, and I did get 308m/s.
  • · Replies 40 ·
  • · Replies 26 ·
