Torque Calculation for Restoring Angular Speed of Two Disks
The discussion focuses on calculating the torque required to restore the angular speed of two disks after they reach a common angular speed upon contact. The first disk has a radius of 0.200 m and mass of 1.00 kg, rotating initially at 10.0 radians/second. The final angular speed after the smaller disk is dropped is 9.4 rad/s, with a fraction of the initial rotational kinetic energy converted to heat calculated at 0.0588. The correct torque required to restore the angular speed is determined to be approximately 0.0913 Nm, correcting for rounding errors in previous calculations.
  • Understanding of rotational dynamics and angular momentum
  • Familiarity with the moment of inertia formula for disks
  • Knowledge of angular acceleration and its calculation
  • Proficiency in handling rounding errors in numerical calculations
  • Study the concept of moment of inertia for various shapes, focusing on disks
  • Learn about angular acceleration and its relationship with torque
  • Explore the effects of friction on rotational motion in mechanical systems
  • Investigate numerical methods for minimizing rounding errors in calculations
Physics students, mechanical engineers, and anyone involved in rotational dynamics and torque calculations will benefit from this discussion.
amcavoy
A uniform circular disk of radius R = 0.200 m and mass M = 1.00 kg rotates with angular speed wo = 10.0 radians/second on a frictionless pivot. A second disk, having half the radius of the first and made of the same material, is supported at rest a small distance above the first disk. When the small disk is dropped concentrically onto the larger disk, friction eventually causes the disks to reach a common angular speed.
What is the final angular speed?
I came up with 9.4 rad/s, which is correct.
What fraction of the initial rotational kinetic energy is converted to heat in the process?
I came up with .0588, which is also correct.
A motor must restore the angular speed of the combination to wo in one revolution. What torque must the motor supply ?
I used the equation [itex]\tau=I\alpha[/itex] here. I added each moment of inertia (for each disk individually):
[tex]I=I_1+I_2=.02125[/tex]
The above I got using the standard formula for the moment of inertia for a disk (1/2)mr2.
Now I found the acceleration:
[tex]10^2=9.4^2+2\alpha\left(2\pi\right)\implies\alpha=.926\text{rad}/\text{sec}^2[/tex]
Then I multiplied the acceleration by the moment of inertia to come up with:
[tex]\tau=.0197\text{Nm}[/tex]
...however the above is incorrect. Could someone please tell me why? I have gone through my steps many times, meaning that the only way this could be wrong is if I took the wrong steps; my arithmetic is fine. I'd appreciate any input on this.
Thank you very much.
your procedure is correct ... your final solution for tau does have some round-off error in it from rounding the final omega from the 1st part of the problem ... 9.4 rad/s.
If you don't round, you should get tau = .0913092394 Nm
If this is an on-line problem that is machine graded, that could be the reason.
Thank you very much. It's nice to know my problem was in rounding digits rather than my procedure (it is web-based homework by the way).
Thanks again.
  • · Replies 45 ·
15K
